    Extrude fault
    • Sorrajakundefined
      Sorrajak
      Extruder show below, what does it mean?
      Error: heating fault on heater 1, temperature rising much more slowly than the expected 0.6°C/sec
      ; Configuration file for Duet WiFi (firmware version 1.16)
      ; generated by RepRapFirmware Configuration Tool on Thu Jan 12 2017 13:33:59 GMT+0700 (SE Asia Standard Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M208 X240 Y240 Z200 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S1 ; Define active high microswitches
      M558 P0 X0 Y0 Z0 H5 F120 T12000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
      G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M350 X16 Y16 Z16 E16 I0 ; Configure microstepping without interpolation
      M92 X80 Y80 Z2560 E92.5872345 ; Set steps per mm
      M203 X12000 Y12000 Z180 E1200 ; Set maximum speeds (mm/min)
      M201 X3000 Y3000 Z500 E250 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S280 ; Set maximum heater temperature to 280C
      M305 P0 T100000 B3988 R4700 ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B3988 R4092 ; Set thermistor + ADC parameters for heater 1
      M563 P0 D0 H1 ; Define tool 0
      G10 P0 X0 Y0 ; Set tool 0 axis offsets
      M550 PTest_12.01.2017 ; Set machine name
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
        It sounds like you haven't run auto tuning since upgrading to a version that supports it. See https://duet3d.com/wiki/Tuning_the_heater_temperature_control.
        • Sorrajakundefined
          Sorrajak
          the problem clear by update new firmware, from 1.15 to 1.17a.
          thx.
