Trouble Shooting - not sure where to start
  • @dc42 I'll try. I am using a Yellow Jacket quick clip so it makes it hard to get a good picture at the hotend side.
    I had the single wires from the PT100 going into the bottomside and then the 4 wires from the top.
    I am going to eliminate that and directly wire everything and see if that works. Just guessing at this point is the Thermistor worked before with the connector
  • Figured it out.
    I believe the PT100 wire gauge was too small to make a good contact in the connector.
    It was good enough for resistance reading but not when things were powered up.
    I seperated out the PT100 wires out and used a smaller JST plug and it's all working now.
    Thanks for the patience.
