    filabase 300*300mm bed with 24v and 450w for duetwifi
    • sunilmulti
      sunilmulti last edited by
      filabase 300*300mm bed with 24v and 450w is suitable for duetwifi please help me to solve this problem
        450W @ 24V is 18.75A, which is above the recommended maximum bed heater current of 18A. You could turn down the PSU voltage to 23V to bring the current in range, or use a SSR - see https://duet3d.dozuki.com/Wiki/Choosing_a_bed_heater#Section_Low_voltage_12V_or_24V_DC_bed_heater.
        • sunilmulti
          sir if i use power supply 24v @ 18A for duetwifi ,so it is ok for 24v and 18.75A heat bed
          T3P3Tony dc42 2 Replies Last reply Reply Quote 0
          • T3P3Tony
            T3P3Tony administrators @sunilmulti last edited by
            @sunilmulti how does your proposed power supply handle overcurrent?
              dc42 administrators @sunilmulti last edited by dc42
              @sunilmulti said in filabase 300*300mm bed with 24v and 450w for duetwifi:
              No. The power supply needs ro be sufficient to power both the bed heater and everything else attached to the Duet. A 24V 600W power supply should suffice.
