Remapped driver
  • Hi, I think this topic has been talked about, but still I do not see the solution. I have burned the driver corresponding to the output of the E0 extruder, and I want to use the E1 output to solve the problem. I have tried with:
    M584 X0 Y1 Z 2 E3 and the only thing I get with this is that the hotend disappears. Right now, as I have configured the config.g I find two extruders in the Machine properties menu and there is no way to eliminate the E0. I want to eliminate E0 because if by mistake it were to work I do not know what could happen, probably more sparks and fire ... Thank you and sorry for my bad English.
    ; generated by RepRapFirmware Configuration Tool on Thu Oct 18 2018 21:09:21 GMT+0200 (CEST)
    M550 PENDER 3 ; Set machine name
    M552 S1 ; Enable network
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M569 P0 S0 ; Drive 0 goes backwards
    M569 P4 S0 ; Drive 3 goes backwards
    ;M584 X0 Y1 Z2 E4
    M350 X256 Y256 Z256 E16 I0 ; Configure microstepping without interpolation
    M92 X1280 Y1280 Z6400 E514 ; Set steps per mm
    M203 X9000 Y9000 Z180 E1200 ; Set maximum speeds (mm/min)
    M201 X575 Y575 Z100 E575 ; Set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X230 Y230 Z250 S0 ; Set axis maxima
    M574 X1 Y1 S1 ; Set active high endstops
    ;M307 H4 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
    M307 H3 A-1 C-1 D-1
    M558 P9 H5 F120 T6000 A3 ; Set Z probe type to bltouch and the dive height + speeds
    G31 P25 X32 Y-2 Z0.35 ; Set Z probe trigger value, offset and trigger height
    M557 X20:200 Y20:200 S45 ; Define mesh grid
    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
    ;M563 P0 D0 H1 ; Define tool 0 cambiado para extrusor E0 pase a E1
    M563 P0 D1 H1
    @danivv said in Remapped driver:
    M584 X0 Y1 Z 2 E3
    That should be:
    M584 X0 Y1 Z2 E4
    The M563 command should be exactly as it was originally:
    M563 P0 D0 H1
    because the M584 command maps extruder drive 0 to driver 4.
  • Thank you very much for your reply. I have made all the changes he suggested, but the E0 continues without disappearing ... And now the E1 does not appear.
    M584 X0 Y1 Z2 E4
    M307 H3 A-1 C-1 D-1
    ; M563 P0 D1 H1
    That's right, it's still E0 even though you have mapped it to driver 4, which is the one whose connector is labelled E1.
  • Ahhhhh Ok!!
    Tahnks!!
    Out of interest, how old is your Duet, and how did you damage the E0 driver? It's rare for the drivers to fail these days.
  • Hello, my duet is a week old, connect an engine (25mm brand pancake bondtech) which did not work, it vibrated a little but it did not turn, one of the times I connected it started to heat up, until they started to jump sparks the duet (my tears also leapt), I think it was the engine's fault despite being new ... I have again asked for another similar one, I'm worried if it happens again ...
    Thank you very much for your interest.
    Where exactly did you see the sparks?
  • In the driver microchip
    Please post more photos of the failed chip, in particular one taken from directly overhead and one taken looking towards the side of the chip close to the damage. I want to check that the chip was correctly aligned with the PCB pads on that side.
    The soldering looks OK, however it's very rare for stepper motors to have shorted windings. So I will give you the benefit of the doubt and approve a warranty replacement for the Duet if you wish to return it.
  • Thank you, I appreciate it very much.
    @danivv it might be worth checking the motor using one of the other (working) stepper channels as well as that will allow you to confirm the motor is working correctly.
  • @t3p3tony
    I thought about doing it, but the engine got very hot and smelled like burnt, and I did not dare to try it for fear of burning another channel.
    @danivv ahh fair enough. Sounds like you could have the current set very high for that motor however I have checked the config.g and the motor:
    https://www.bondtech.se/en/product/nema17-pancake-stepper-25mm/
    and if the motor is working correctly the 500mA should be ok, which is what you have it set to.
  • @t3p3tony
    If just that, from 0.7A, I have asked for another equal ...
    Do you have a multimeter? if so, you can measure the resistance of each phase. Also make sure there is no continuity between the two phases, or between either phase and the case of the motor.
    Does the motor have wires coming out of it, or does it have a 6-pin connector on it? If it has a connector, it is possible that the colours of the wires do not correspond to the usual phase colours.
  • @dc42
    Following the diagram I have attached the winding A and B. In both gives me continuity without resistance, ie short circuit. And endless resistance between them.
    I can do some more test, if you want. It seems that the duet works correctly except for the E0 output.
    Can your multimeter measure as low as 4.2 ohms?
