Startup problem - ground?
after some hours of printing SD card died.
After changing SD card and printing some more hours strange thing happened.
Looks like some hardware problems?
Board is trying to boot up, but it is looping.
https://youtu.be/6rEjPdk68i8
Have changed it with board from other printer - works perfectly.
Should I send for replacement?
@alishkus can you try it with nothing plugged in and with a different SD card that has all th config on it. I wonder what caused the first SD card to fail? How long was it working for? When you say you swapped the board with another working one was that the Duet or the Duex or both?
Ok.
I have unplugged everything and insert new SD card with fresh config.
Same stuff happens (can upload video if needed)
Some time it starts up, but its not stable. Usually restarts itself 1 hour into print...
It was working roughly for 50-70hours of printing
First SD failed without any intervention - just in the middle of print.
I have swapped only Duet Wifi.
@alishkus please can you run M122 after it fails but before you power cycle the printer.
M122
Used output buffers: 3 of 32 (9 max)
RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later + DueX2
Board ID: 08DGM-956GU-DJMSN-6JTDG-3SN6T-9UNMD
Static ram used: 16152
Dynamic ram used: 100408
Recycled dynamic ram: 2224
Stack ram used: 1224 current, 4528 maximum
Never used ram: 7760
Last reset 00:00:29 ago, cause: reset button or watchdog
Last software reset at 1969-12-31 23:59, reason: deliberate Unknown, spinning module none, available RAM 4294967295 bytes (slot 0)
Software reset code 0xffff HFSR 0xffffffff, CFSR 0xffffffff, ICSR 0xffffffff, BFAR 0xffffffff, SP 0xffffffff
Error status: 0
Free file entries: 10
MCU temperature: min 44.4, current 45.4, max 47.0
Supply voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0
Driver 5: standstill, SG min/max not available
Driver 6: standstill, SG min/max not available
Expansion motor(s) stall indication: no
Date/time: 2018-10-29 13:55:21
Slowest main loop (seconds): 0.014302; fastest: 0.000052
MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Scheduled moves: 0, completed moves: 0
Bed compensation in use: none
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.20
WiFi MAC address 5c:cf:7f:76:63:ad
WiFi Vcc 3.32, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 16552
WiFi IP address 10.10.65.9
WiFi signal strength -68dBm, reconnections 0, sleep mode modem
Socket states: 2 0 0 0 0 0 0 0
=== Expansion ===
DueX I2C errors 0
- WiFi -
Is there any fast way to find a bug?
Because this issue caused me quite some money and client problems...
Please try the following:
Check whether are components on the Duet are getting hot, in particular the WiFi module, the 3.3V regulator (U2) and the main processor.
Update the firmware to 2.01 or 2.02RC3.
With only power connected, check if the problem (looping when booting up) still occurs.
If it still occurs, replace the config.g file with an empty one and see if it boots up. You will be able to tell by watching the DIAG LED, I think.
If it does boot up, add M552 S1 to config.g and see if it boots up.
- No particular place of board is getting hot
- Have tried both various updates and downgrades. Strange thing I cant upload any software via webcontrol (no response)
- Only Duet wifi - problem still occurs
- Have tried blank config.g - almost thought it worked but then board started looping again
Doesnt look like firmware for me. I would guess CPU or SD reader, but cant really test them...
It does sound that your Duet may be faulty, so I suggest you ask for a replacement.
