    Problems with PWM Heater-Pins
    My Duet controlled machine
    • Kakadu31undefined
      Kakadu31
      When I disable the Heater-Pin as such and try to use it as PWM Pin, the duty cycle does not drop from 100% to 0% when I try S255 vs S0. If I invert the logic trough a I in the G-code, the duty cycle goes from 0% to 10% (rough value estimated from the oscilloscope data). I tested this behaviour for several Heater-Pins.
      Is there anyone familiar with this problem?
      Greeting, Kakadu31.
        Did you specify the PWM frequency? If so, what frequency did you specify?
        Which firmware version are you using?
        • Kakadu31undefined
          Kakadu31
          Hey thx for your answer. I did not specify the Frequency, I was not even aware of the possibility. I used RepRapFirmware 1.21
          • T3P3Tonyundefined
            T3P3Tony administrators @Kakadu31
            @kakadu31 have a look at the M106 documentation:
            https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
            It shows how to set the frequency etc.
            That said you should expect the defaults to work properly in most normal situations.
            www.duet3d.com
