    Delta 3D space head positioning vs single tower moves
    943
    • Chipsa82undefined
      Chipsa82
      Im running the duet wifi with 2.01beta1(RTOS) (2018-06-23b1) firmware on my delta printer.
      Everything seems to be working fine, except the manual machine control in the web interface. by clicking i.e. move Z down by -100mm, only the Z tower carriage moves down. the same applies for other axes/carriages.
      If I enter a manual gcode command, i.e. G1 X50 Y20 Z100 F3000, everything works OK and the printhead moves where it should.
      any clue why the web interface doesn't move all carriages accordingly but just the individual towers?
      thanks!
      • T3P3Tonyundefined
        T3P3Tony administrators
        That is odd! As a start point I would update the firmware: https://github.com/dc42/RepRapFirmware/releases
        www.duet3d.com
        • Chipsa82undefined
          Chipsa82
          Indeed..
          looking at the console log, if i push one of the buttons in the screenshot above, i get this output per buttonpress
          M120
          G91
          G1 S2 X-10 F6000
          M121
          looking at the G1 gcode wiki
          G1 Xnnn Ynnn Znnn S2 Ignore endstops while moving. Also ignore if axis has not been homed. On Delta (only), axis letters refer to individual towers.
          so it looks like the S2 parameter (saying not to move the printhead but just the corresponding tower) is there by design.
          i tried looking up where to adjust this (=leave out the S2) in the web UI, but no luck.
          • T3P3Tonyundefined
            Please do try with the latest firmware and DWC.
            www.duet3d.com
            • Dougal1957undefined
              Dougal1957
              Also please post your Config.g file
                dc42 administrators @Chipsa82
                @chipsa82 said in Delta 3D space head positioning vs single tower moves:
                Indeed..
                M120
                G91
                G1 S2 X-10 F6000
                M121
                Updating Duet Web Control will fix that. You should also update the main firmware, because you are running an obsolete release candidate version.
                • Chipsa82undefined
                  Chipsa82
                  thanks, will give it a try!
                  • Chipsa82undefined
                    Chipsa82
                    Hi
                    thanks for the advice
                    upgrading Web Interface to Version 1.22.3 resolved the issue
                    thanks!
