    Schematics for PT100 board not on Github?
    • DocTrucker
      DocTrucker last edited by
      Hi all,
      Can someone point me toward the schematics for the PT100 daughter board? I can't see them on the Github.
      Alternatively looking for an economic MAX31865 card with 400Ohm reference resistors rather than the 430 that seems common on ebay.
      Thanks.
        You can use interface boards with 430 ohm resistors with recent firmware versions because the M305 command accepts an R parameter. However, if you have a Duet WiFi or Duet Ethernet then I suggest you buy the official daughter board to use it with PT100 sensors, otherwise we can't support you if it doesn't work.
        • DocTrucker
          Thanks for the clarification regarding the 430ohm. You may wish to tweek the wiki in relation to connecting PT100 to v0.6 boards - it still suggests a board with a 400ohm reference resistor.
          Where's the schematic for the PT100 daughter boards?
          • T3P3Tony
            T3P3Tony administrators @DocTrucker last edited by
            @doctrucker the temperature daughter board schematics an kiCAD projects are shared on the T3P3 github. Here is the PT100 schematic:
            https://github.com/T3P3/TempDaughterboards/blob/master/MAXTempRTD/MAXTempRTDv1.1.pdf
            • DocTrucker
              Thanks. Was looking on the right github but wrong place!
