AC vs DC Ground?
This really isn't a duet specific question... it's more of a general "best practices" question for wiring DC electronics with an AC power supply.
I think I remember reading (but can't find it now) where someone said that when wiring the duet, the A/C "ground" terminal from the PSU (AC Ground) should be shorted with the PSU's DC Negative (DC Ground or DC-) terminal and the printer chassis (and stepper motor bodies, etc.)
Is this correct?
Thanks
Gary -
Yes that's correct.
AC ground and DC negative should be connected together at one point. The PSU terminals are a suitable point, but not the only possibility.
Worth checking your specific PS. Quite a few have the gnds connected internally already.
...others also have filtering circuits that would be shorted out by linking DC and AC ground?
