    Calibration Stand Still noise- activate single motor only?
    • kuhnikuehnastundefined
      kuhnikuehnast
      Hi there,
      as I want to calibrate the stand still noise of my printer, I was looking for a G-Command to move only a single motor. (I am using a CoreXY-Design and a Dual Z-Axis) Is this possible or do I have to plug / unplug all steppers one by another?
      Greetings kuhni
        You can move the X and Y motors individual using G1 S2 commands. See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Commissioning.
        To move the Z motors independently, I suggest you use M584 to temporarily assign just one of your two Z motors to the Z axis. Don't forget to put it back afterwards!
        • T3P3Tonyundefined
          T3P3Tony administrators @dc42
          I have updated the G0/G1 gcode documentation as well:
          https://duet3d.dozuki.com/Wiki/Gcode?#Section_G0_G1_Move
          G1 Xnnn Ynnn Znnn S2 Ignore endstops while moving. Also ignore if axis has not been homed. On Delta and CoreXY, axis letters refer to individual towers.
          www.duet3d.com
