    Precision Piezo Orion react late...
    Third-party add-ons
    • peirofundefined
      peirof
      because for a few days I am having problems with the sensor, Precision Piezo. Until yesterday it worked, PERFECT, but a couple of days ago I got some failure, I explain:
      Hardware that I use.
      • TLM printer
      • Duet plate
      • Extruder Prometheus v2.
      • Precision Piezo Orion
      The problem....
      When I give it to calibrate, or to make the Heightmap for the compensation, the same problem, in 75% of the surface of the base the test points work perfectly, with a soft touch ... but in 25%, maybe less, which corresponds to a quadrant of the base, you hear a hard hit (Hard Tap).
      If I try PPO (Precision Piezo Orion), hitting the nozzle gently with an object, it detects the object, but in that area of ​​the bed, it seems as if it takes longer to react.
      Before this, when it came out the summary of the calibration, the deviation was VERY low, 0.1 mm, since I happened this has risen to 0.35 mm approx.
      I'm using PPO, this way in config.g
      M558 P8 I1 R0.4 F300 X0 Y0 Z0
      G31 X0 Y0 Z-0.1 P100
      But I have tried like M558 P5, and similar, even more strong touches.
      Any idea of ​​what I can do.
      I HAVE NOT TOUCHED THE POTENTIOMETER OF HOW IT COMES, TO WHICH AT THE BEGINNING I WORKED PERFECT.
      Thank you
      • Moriquendiundefined
        Moriquendi
        @moriquendi said in Precision Piezo Orion: Errors when probing:
        Another thing that often helps in situations like this is to loosen the four assembly screws slightly, start with 0.5 turns and test, repeat if necessary.
        Idris
        • peirofundefined
          peirof
          thanks, later try... and give feedback
          • peirofundefined
            peirof
            Checked... WORKS FOR ME...
            Thanks @moriquendi
              Moriquendi
              Excellent, good news.
              Idris
