    Anyone running a Filament sensor on Maestro?
    • cabal2000undefined
      cabal2000
      Looking for the pinup to run a filament sensor on my Maestro but can't seem to find most. Any help would be great.
        What type of filament sensor is it?
          cabal2000
          3 wire micro switch. Printed a housing for it.
          • iratecrayonsundefined
            iratecrayons
            I'm running a lerdge V2 filament sensor. Also 3-wire, look up the wiring on google images, and use the Maestro wiring diagram to connect to "E0 Stop" (next to limit switch connectors).
              dc42 administrators @cabal2000
              @cabal2000 said in Anyone running a Filament sensor on Maestro?:
              It should work with the Maestro. Find the 2 contacts that are closed when filament is present, and connect them to the 2 outer pins of a spare endstop input. Then configure it using M591, sensor type 2.
