    Script for BLTouch Commands
    • roth
      roth last edited by
      Hello
      I want to save a Script to reset the BLTouch Sensor.
      The Sensor works but i not find the correct Command.
      I find :
      M280 PS3 Set BLTouch to probing position : light on, pin out (1).
      M280 PS10.6Reset the BLTouch
      M280 PS7Set BLTouch to idle position
      M280 PS8SELF TEST
      But it comes :
      M98 P"0:/macros/BLTouch Reset"
      Error: Invalid servo index 0 in M280 command
        Have you seen this?
        https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
        M280 P3 S10 I1 ; deploy
        M280 P3 S90 I1 ; retract
        M280 P3 S120 I1 ; test mode
        M280 P3 S160 I1 ; clear test mode or error condition
        P3 is used in that example because it assumes you're using heater pin 3.
        In your test it looks like you don't have a P# selected
        • roth
          roth last edited by
          Thank you
          I probably missed something. Because the commands look different than mine.
