    Maximum motor size for X&Y on core-XY printer
    1.5k
    • gnydickundefined
      gnydick
      I have a Promega (yes, I appreciate the sympathetic crying). The xy motors seem to get rocket hot when trying to print fast. Even at 680mA which is the default current. So, it skips steps.
      Am I right in thinking a motor with more windings will be able to run faster? I'm looking at Moons nema 17 that are quite long any rated at .88Nm torque.
      I don't know what the stock motors are on this machine, but I wouldn't be surprised if they're junk.
      gnydickundefined 1 Reply Last reply Reply Quote 0
      • gnydickundefined
        gnydick @gnydick
        @gnydick here's the motor
        Moons' NEMA17 Stepper Motor 3D Printer 0.88Nm(125oz-in)1.5A2Phase 1.8 Degree Stepper Motor 62.8mm(2.47in.) 3Stack Smooth Stepper Motor (Stepper Motor Cable00723 Include, Model MS17HDBP4150) https://www.amazon.com/dp/B07G429DL3/ref=cm_sw_r_cp_apa_i_P3r3BbD3CR0QD
          Motors running hot doesn't cause them to skip steps. Things that cause skipped steps include:
          • Motor current too low (which isn't the case if they are getting hot)
          • Mechanical issue causing high friction or stickiness
          • Acceleration set too high in the M201 command, so that the motor can't produce enough torque for the acceleration demanded
          • Jerk set too high in M566
          • Using stealthChop driver mode at high speeds (see the V parameter of the M569 command)
          • Insufficient power supply voltage for the motor inductance and the speed you are trying to run them at. Use the motor EMF calculator at https://reprapfirmware.org/ to check.
          If it's the last one, then changing to lower inductance/higher current motors (and then increasing the motor current) will help. For the drivers on the Maestro I suggest you aim for a rated current around 1.3A.
          • gnydickundefined
            gnydick
            Ok. That all makes sense. I'm also hearing a loud "clack" when the motors engage sometimes. This is something new. Any idea what that may be?
            I do have a nice motor initialization routine with progressively increasing speed to train the stealthchop system. Sorry the terms in using may be wrong, I just know you want to move slowly at first.
            • gnydickundefined
              gnydick
              I'm trying higher current and it doesn't seem to matter. I just keep hearing a 'clank' while it's printing. I thought before they were rocket hot. NOW they're rocket hot at 900mA. Here are my settings.
              M201 X1000 Y1000 Z75 E2000:2000 ; accleration
              M203 X24000 Y24000 Z2400 E5000:5000 ; velocity
              M566 X1200 Y1200 Z40 E2000:2000 ; jerk
              M906 X900 Y900 Z1000 E500:500 I60; Set motor currents (mA) and idle current percentage (dual Z-motors)
              I just keep getting clunks while it's printing. Sometimes they're diagonal, but not at 45, sometimes they're horizontal, and sometimes they're vertical.
              • gnydickundefined
                gnydick
                I was just printing a really slow print and "CLANK", skipped step. I don't know what to do. 😞
                  The clank could be the stepper drivers switching from stealthChop to spreadCycle mode. When you send M569 P0 what changeover speed does it report?
                  I suggest you try configuring the drivers to run in spreadCycle mode all the time, to determine whether stealthChop is part of the problem.
                  • deckingmanundefined
                    deckingman @gnydick
                    @gnydick Are you sure the "clank" is coming from the motors? Is it all the motors or just one of them?
                    • gnydickundefined
                      gnydick @deckingman
                      @deckingman @dc42 Turns out it was loose belts that were slipping one tooth at a time.
