    Page refresh
    1.3k
    • Fodenundefined
      Foden
      I use Chrome as my browser with the Duet Wi-Fi and the page refresh drives me crazy. On my PC the browser window isn't big enough to show everything on one page without any vertical scroll bars. Not typically an issue as you simply scroll down to see the other information. However, on my setup the screen jumps back top the very top, presumably doing a refresh, after about a second. What causes this and how do i stop it
      Thanks in advance
      Danalundefined 1 Reply Last reply Reply Quote 0
        Which versions of DWC and Chrome are you using?
        • Fodenundefined
          Foden
          Chrome Version 70.0.3538.77 (Official Build) (64-bit) and DWC Version 1.22.4. Both are the latest I believe
            Thanks, also which page or pages of DWC does it happen on? Does it happen even when the printer is idle?
            • Fodenundefined
              Foden
              It does it on any page that has vertical scroll gadgets and is the same whether the printer is printing or idle
              • chrishammundefined
                chrishamm administrators
                Can you check if toggling "Always show info area" on the Settings page makes a difference?
                Duet software engineer
                • Fodenundefined
                  Foden
                  Interesting, turning it off seems to have done the trick. However turning it back on doesn't make it jump any more. Will see how it goes and report back
                  • Nikolas2810undefined
                    Nikolas2810
                    Works for me as well ! Thanks !
                    Small observation the page refresh was not happening two months ago. I wonder if a chrome update slipped undetected and caused this "bug".
                    • NitroFreakundefined
                      NitroFreak
                      Is there any fix for this yet? I have the newest everything and this drives me nuts, i cannot select old gcode files to reprint as it always jumps back up. Toggling the "always show info area" does nothing
                        droftarts administrators
                        I don't get this behaviour in Firefox, don't have Chrome installed to test. Another option is to 'Zoom out' so everything is smaller, but fits on the page. Might not work for a long list of files in the Jobs folder, though.
                          dc42 administrators @droftarts
                          I've never seen this problem with Duet Web Control 2.
                          • Danalundefined
                            Danal @Foden
                            @Foden said in Page refresh:
                            Thanks in advance
                            I use Chrome constantly with DWC1 and DWC2. I've tried to force the behavior you describe and have never seen it happen. Given several others have said this, it must be something unique to your Chrome install.
                            Have you tried turning off all plugins in chrome? Re-installing? etc, etc. If you are on Windows, have you tried Edge (JUST, and I repeat, ONLY, for debugging)?
                            Fodenundefined 1 Reply Last reply Reply Quote 0
                            • Fodenundefined
                              Foden @Danal
                              @Danal Yikes - this was from a year ago - lots of people have mentioned this. It's a "Feature" of the web control. Belive it was chrishamm that gave me the the solution I had to toggle Off the "always show info area" - on this very page
                              • Danalundefined
                                Danal
                                The restart post says:
                                @NitroFreak said in Page refresh on 23 Oct 2019:
