Space in SSID: Correct Syntax Please
  • undefined
    lasakro
    I read that the instructions mention that the space requires quotes around it but dosen't mention how to handle the remaing SSID. I've tried several attempts but it's kicking my "but".
    Ex: M587 S"Bobs Home" P"8312831283128312"
    All combinations don't find any network after a M552 S1:
    "Bobs"" ""Home"
    "Bobs" "Home"
    'Bobs'" "'Home'
    undefined 1 Reply Last reply 7 Nov 2018, 08:35 Reply Quote 0
    • undefined
      themelle
      @lasakro said in Space in SSID: Correct Syntax Please:
      M587
      You may consider using single quotes as stated in https://duet3d.dozuki.com/Wiki/Gcode#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks to mark characters as lower case, e.g. for your example
      M587 S"B'o'b's H'o'm'e" P"8312831283128312"
      • undefined
        dc42 administrators @lasakro
        That is the correct syntax, assuming that "Bobs Home" (without the quotes) is the SSID. However, some GCode senders (e.g. Pronterface) convert all characters to uppercase before sending, so it would be sent as BOBS HOME which won't match your SSID. To avoid this, either use a terminal emulator to send the M587 command (e.g. YAT under Windows), or put the M587 command in a temporary macro file on the SD card and execute that, or prefix each lowercase character with a single quote mark as @themelle indicated.
        • undefined
          lasakro
          Thanks for the reply's guys. Got it to work. Looks like the Wiki still has an outdated info about the space used in a SSID for M587:
          "If a password or SSID includes space or semicolon characters then it must be enclosed in double quotation marks. For security, do not use this command in the config.g file, or if you do then remove it after running it once so that the network password is not visible in the file."
          undefined 1 Reply Last reply 8 Nov 2018, 00:14 Reply Quote 0
          • undefined
            lasakro @lasakro
            Or maybe better clarification. 🙂
            • undefined
              Thanks, I have corrected the description of M587 in the GCodes wiki page.
              1 out of 6
