So close to printing getting Error: G1/G2/G3:
  • Howdy again,
    Ok I'm soooo close I can just about taste it. I can get my delta (old monoprice garbage) to heat up, auto home, and run thru the delta auto calibration. And it gives me that 3d picture of my very uneven glass. When I go to print it runs thru the auto calibration setup and then gives me the "Error: G1/G2/G3: intermediate position outside machine limits ." I know that I'm so close to printing that I just must be missing something. I'll include my cura settings and config files.
    Starting G code from Cura:
    G28 ;Home
    G32
    ;G29 S1
    G92 E0 ; Set the extruder to zero
    G1 E8 ; Prime the nozzle
    Config files
    ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
    M665 R105.6 L215 B85 H310 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
    M92 X80 Y80 Z80 E663 ; Set steps per mm
    M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
    M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
    M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 Z310 S1 ; Set minimum Z
    M574 X2 Y2 Z2 S1 ; Set active high endstops
    M558 P5 R0.4 H5 F1200 T6000 ; Set Z probe type to effector and the dive height + speeds
    G31 P100 X0 Y0 Z-0.1 ; Set Z probe trigger value, offset and trigger height
    M557 R85 S20 ; Define mesh grid
    M563 P0 D0 H1 ; Define tool 0
    ; Automatic power saving
    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
    So I'm again back just asking for some help from the Duet Wifi heros.
    Thanks again for even looking and I can't wait to have the smell of pla printing on this machine!!!
    Bill in colorado
  • Can you post a small section of the gcode you are trying to print, up to and including the first few G1 lines?
    I'm wondering if your slicer has its origin misaligned with the forward or similar.
  • Ok so this is going to sound stupid. I don't know how to look that up. Any ideas or tips?
    Sorry for the noob problem, this is all new to me.
    Bill in colorado
  • The gcode file is the one that cura produces. Open it in notepad and copy the first 20 lines or so.
  • Ah I knew there was something easy.
    It doesn't make sense to me but here it is.
    ;TIME:1122
    ;Filament used: 0.614537m
    ;Layer height: 0.3
    ;Generated with Cura_SteamEngine 3.5.1
    T0
    M190 S60
    M104 S200
    M109 S200
    M82 ;absolute extrusion mode
    G28 ;Home
    G32
    ;G29 S1
    M83 ;relative extrusion mode
    G1 F1500 E-6.5
    ;LAYER_COUNT:67
    ;LAYER:0
    M107
    G0 F3600 X17.8 Y-10 Z0.3
    ;TYPE:SKIRT
    G1 F1500 E6.5
    G1 F1800 X17.8 Y10 E0.37621
    G1 X17.76 Y10.789 E0.01486
    G1 X17.641 Y11.569 E0.01484
    G1 X17.443 Y12.334 E0.01486
    G1 X17.169 Y13.074 E0.01484
    G1 X16.821 Y13.783 E0.01486
    G1 X16.403 Y14.454 E0.01487
    G1 X15.92 Y15.078 E0.01484
    G1 X15.377 Y15.651 E0.01485
    G1 X14.778 Y16.166 E0.01486
    G1 X14.13 Y16.617 E0.01485
    G1 X13.439 Y17.001 E0.01487
    G1 X12.714 Y17.313 E0.01485
    G1 X11.961 Y17.55 E0.01485
    G1 X11.187 Y17.709 E0.01486
    G1 X10.402 Y17.79 E0.01484
    G1 X10 Y17.8 E0.00756
    G1 X-10 Y17.8 E0.37621
    G1 X-10.789 Y17.76 E0.01486
    G1 X-11.569 Y17.641 E0.01484
    G1 X-12.334 Y17.443 E0.01486
    G1 X-13.074 Y17.169 E0.01484
    G1 X-13.783 Y16.821 E0.01486
    G1 X-14.454 Y16.403 E0.01487
    G1 X-15.078 Y15.92 E0.01484
    G1 X-15.651 Y15.377 E0.01485
    G1 X-16.166 Y14.778 E0.01486
    G1 X-16.617 Y14.13 E0.01485
    G1 X-17.001 Y13.439 E0.01487
    G1 X-17.313 Y12.714 E0.01485
    G1 X-17.55 Y11.961 E0.01485
    G1 X-17.709 Y11.187 E0.01486
    G1 X-17.79 Y10.402 E0.01484
    G1 X-17.8 Y10 E0.00756
    G1 X-17.8 Y-10 E0.37621
    G1 X-17.76 Y-10.789 E0.01486
    G1 X-17.641 Y-11.569 E0.01484
    G1 X-17.443 Y-12.334 E0.01486
    G1 X-17.169 Y-13.074 E0.01484
    G1 X-16.821 Y-13.783 E0.01486
    G1 X-16.403 Y-14.454 E0.01487
    G1 X-15.92 Y-15.078 E0.01484
    G1 X-15.377 Y-15.651 E0.01485
    G1 X-14.778 Y-16.166 E0.01486
    G1 X-14.13 Y-16.617 E0.01485
    G1 X-13.439 Y-17.001 E0.01487
    G1 X-12.714 Y-17.313 E0.01485
    G1 X-11.961 Y-17.55 E0.01485
    G1 X-11.187 Y-17.709 E0.01486
    G1 X-10.402 Y-17.79 E0.01484
    G1 X-10 Y-17.8 E0.00756
    G1 X10 Y-17.8 E0.37621
    G1 X10.789 Y-17.76 E0.01486
    G1 X11.569 Y-17.641 E0.01484
    G1 X12.334 Y-17.443 E0.01486
    G1 X13.074 Y-17.169 E0.01484
    G1 X13.783 Y-16.821 E0.01486
    G1 X14.454 Y-16.403 E0.01487
    G1 X15.078 Y-15.92 E0.01484
    G1 X15.651 Y-15.377 E0.01485
    G1 X16.166 Y-14.778 E0.01486
    G1 X16.617 Y-14.13 E0.01485
    G1 X17.001 Y-13.439 E0.01487
    G1 X17.313 Y-12.714 E0.01485
    G1 X17.55 Y-11.961 E0.01485
    G1 X17.709 Y-11.187 E0.01486
    G1 X17.79 Y-10.402 E0.01484
    G1 X17.8 Y-10 E0.00756
    G0 F3600 X17.4 Y-10
    G1 F1800 X17.4 Y10 E0.37621
    G1 X17.36 Y10.768 E0.01447
    G1 X17.241 Y11.528 E0.01447
    G1 X17.043 Y12.271 E0.01446
    G1 X16.769 Y12.99 E0.01447
    G1 X16.422 Y13.676 E0.01446
    G1 X16.006 Y14.323 E0.01447
    G1 X15.525 Y14.923 E0.01447
    G1 X14.984 Y15.47 E0.01447
    G1 X14.389 Y15.958 E0.01448
    G1 X13.747 Y16.381 E0.01446
    G1 X13.064 Y16.736 E0.01448
    G1 X12.349 Y17.017 E0.01445
    G1 X11.607 Y17.223 E0.01449
    G1 X10.849 Y17.351 E0.01446
    G1 X10 Y17.4 E0.016
    G1 X-10 Y17.4 E0.37621
    G1 X-10.768 Y17.36 E0.01447
    G1 X-11.528 Y17.241 E0.01447
    G1 X-12.271 Y17.043 E0.01446
    G1 X-12.99 Y16.769 E0.01447
    G1 X-13.676 Y16.422 E0.01446
    G1 X-14.323 Y16.006 E0.01447
    G1 X-14.923 Y15.525 E0.01447
    G1 X-15.47 Y14.984 E0.01447
    G1 X-15.958 Y14.389 E0.01448
    G1 X-16.381 Y13.747 E0.01446
    G1 X-16.736 Y13.064 E0.01448
    G1 X-17.017 Y12.349 E0.01445
    G1 X-17.223 Y11.607 E0.01449
    G1 X-17.351 Y10.849 E0.01446
    G1 X-17.4 Y10 E0.016
    G1 X-17.4 Y-10 E0.37621
    G1 X-17.36 Y-10.768 E0.01447
    G1 X-17.241 Y-11.528 E0.01447
    G1 X-17.043 Y-12.271 E0.01446
    G1 X-16.769 Y-12.99 E0.01447
    G1 X-16.422 Y-13.676 E0.01446
    G1 X-16.006 Y-14.323 E0.01447
    G1 X-15.525 Y-14.923 E0.01447
    G1 X-14.984 Y-15.47 E0.01447
    G1 X-14.389 Y-15.958 E0.01448
    G1 X-13.747 Y-16.381 E0.01446
    G1 X-13.064 Y-16.736 E0.01448
    G1 X-12.349 Y-17.017 E0.01445
    G1 X-11.607 Y-17.223 E0.01449
    G1 X-10.849 Y-17.351 E0.01446
    G1 X-10 Y-17.4 E0.016
    G1 X10 Y-17.4 E0.37621
    G1 X10.768 Y-17.36 E0.01447
    G1 X11.528 Y-17.241 E0.01447
    G1 X12.271 Y-17.043 E0.01446
    G1 X12.99 Y-16.769 E0.01447
    G1 X13.676 Y-16.422 E0.01446
    G1 X14.323 Y-16.006 E0.01447
    G1 X14.923 Y-15.525 E0.01447
    G1 X15.47 Y-14.984 E0.01447
    G1 X15.958 Y-14.389 E0.01448
    G1 X16.381 Y-13.747 E0.01446
    G1 X16.736 Y-13.064 E0.01448
    G1 X17.017 Y-12.349 E0.01445
    G1 X17.223 Y-11.607 E0.01449
    G1 X17.351 Y-10.849 E0.01446
    G1 X17.4 Y-10 E0.016
    G0 F3600 X17 Y-10
    G1 F1800 X17 Y10 E0.37621
    G1 X16.96 Y10.747 E0.01407
    G1 X16.841 Y11.485 E0.01406
    G1 X16.643 Y12.207 E0.01408
    G1 X16.37 Y12.903 E0.01406
    G1 X16.023 Y13.566 E0.01408
    G1 X15.608 Y14.189 E0.01408
    G1 X15.129 Y14.763 E0.01406
    G1 X14.592 Y15.284 E0.01407
    G1 X14.002 Y15.743 E0.01406
    G1 X13.366 Y16.138 E0.01408
    G1 X12.692 Y16.462 E0.01407
    G1 X11.987 Y16.712 E0.01407
    G1 X11.259 Y16.886 E0.01408
    G1 X10.517 Y16.981 E0.01407
    G1 X10 Y17 E0.00973
    G1 X-10 Y17 E0.37621
    G1 X-10.747 Y16.96 E0.01407
    G1 X-11.485 Y16.841 E0.01406
    G1 X-12.207 Y16.643 E0.01408
    G1 X-12.903 Y16.37 E0.01406
    G1 X-13.566 Y16.023 E0.01408
    G1 X-14.189 Y15.608 E0.01408
    G1 X-14.763 Y15.129 E0.01406
    G1 X-15.284 Y14.592 E0.01407
    G1 X-15.743 Y14.002 E0.01406
    G1 X-16.138 Y13.366 E0.01408
    G1 X-16.462 Y12.692 E0.01407
    G1 X-16.712 Y11.987 E0.01407
    G1 X-16.886 Y11.259 E0.01408
    G1 X-16.981 Y10.517 E0.01407
    G1 X-17 Y10 E0.00973
    G1 X-17 Y-10 E0.37621
    G1 X-16.96 Y-10.747 E0.01407
    G1 X-16.841 Y-11.485 E0.01406
    G1 X-16.643 Y-12.207 E0.01408
    G1 X-16.37 Y-12.903 E0.01406
    G1 X-16.023 Y-13.566 E0.01408
    G1 X-15.608 Y-14.189 E0.01408
    G1 X-15.129 Y-14.763 E0.01406
    G1 X-14.592 Y-15.284 E0.01407
    G1 X-14.002 Y-15.743 E0.01406
    G1 X-13.366 Y-16.138 E0.01408
    G1 X-12.692 Y-16.462 E0.01407
    G1 X-11.987 Y-16.712 E0.01407
    G1 X-11.259 Y-16.886 E0.01408
    G1 X-10.517 Y-16.981 E0.01407
    G1 X-10 Y-17 E0.00973
    G1 X10 Y-17 E0.37621
    G1 X10.747 Y-16.96 E0.01407
    G1 X11.485 Y-16.841 E0.01406
    G1 X12.207 Y-16.643 E0.01408
    G1 X12.903 Y-16.37 E0.01406
    G1 X13.566 Y-16.023 E0.01408
    G1 X14.189 Y-15.608 E0.01408
    G1 X14.763 Y-15.129 E0.01406
    G1 X15.284 Y-14.592 E0.01407
    G1 X15.743 Y-14.002 E0.01406
    G1 X16.138 Y-13.366 E0.01408
    G1 X16.462 Y-12.692 E0.01407
    G1 X16.712 Y-11.987 E0.01407
    G1 X16.886 Y-11.259 E0.01408
    G1 X16.981 Y-10.517 E0.01407
    G1 X17 Y-10 E0.00973
    G0 F3600 X16.6 Y-10
    G1 F1800 X16.6 Y10 E0.37621
    G1 X16.56 Y10.725 E0.01366
    G1 X16.441 Y11.442 E0.01367
    G1 X16.243 Y12.141 E0.01367
    G1 X15.97 Y12.814 E0.01366
    G1 X15.625 Y13.453 E0.01366
    G1 X15.211 Y14.05 E0.01367
    G1 X14.735 Y14.598 E0.01365
    G1 X14.201 Y15.091 E0.01367
    G1 X13.616 Y15.521 E0.01366
    G1 X12.987 Y15.885 E0.01367
    G1 X12.322 Y16.178 E0.01367
    G1 X11.629 Y16.396 E0.01367
    G1 X10.917 Y16.536 E0.01365
    G1 X10 Y16.6 E0.01729
    G1 X-10 Y16.6 E0.37621
    G1 X-10.725 Y16.56 E0.01366
    G1 X-11.442 Y16.441 E0.01367
    G1 X-12.141 Y16.243 E0.01367
    There is a huge amt of code from there, if you need more let me know and I hope this helps someone. I must be missing something very small.
    Thanks again to all or any who read and or help,
    Bill in colorado
  • @trout-thug said in So close to printing getting Error: G1/G2/G3::
    G
    Your M208 line in config.g is telling Reprapfirmware that the minimum z position is 320. Calibration ignores this setting but when you go to print z is well below 320, so the move fails.
    I'd change that line to something like
    M208 Z-0.1 S1
  • Don't know if Deltas are different but on CoreXYs and Cartesians, M208 S0 sets the axes maxima and M208 S1 sets the axes minima. If Deltas are the same, then you'd need to change the "S1" to "S0" for the M208 in config.g.
  • @adavidm said in So close to printing getting Error: G1/G2/G3::
    M208 Z-0.1 S1
    Ok sorry I have been at my sons lacrosse tournament in California, I'm booting up my delta right now with the change. I'll report back when I make the changes.
    Again thanks,
    Bill in colorado
  • Ok its closer now the extruder motor isn't feeding the pla, alot of clicking from the motor so I will investigate to see why it isn't feeding the pla into the hot end.
    But it is slowly looking like it should and when it tried to print the hot end was much closer to the build plate.
    Getting excited and thank you to all who have helped. There is no way that I would be able to do this on my own. So thank you again.
    Bill in colorado
  • What temperature are you trying to print at? What kind of extruder is it?
  • So another step closer and more tweaking. Its a smart effector and 200 temp. The problem now is that the hot end is too close to the build surface. Its not allowing the pla to come out of the end. I run the automatic bed leveling and from there its just too close to the build surface. I will try tomorrow again to go over the initial steps of getting the bed level but the change in the M208 command got me closer.
    So I'll try again tomorrow, and thanks,
    Bill in colorado
  • You probably just need to tweak the z value in your g31 command.
    Try making it -0.2. There are better ways than just guessing but that should be enough of a change to notice if things are going in the right direction.
  • Ah haa, I just found another problem. My extruder motor is going in the wrong direction. After forcing the pla thru I was able to get some plastic on the buildplate so how does one change the extruder in the correct direction and I believe I can finally over 3 months print my test cube. I can't believe that it is something as simple as that. But with the z height change I can atleast now get the plastic thru.
    I'm getting giddy with the closeness of this project.
    Thanks adavidm,
    Bill in colorado
  • Ok just a quick google search and M569 P3 S0 made the difference. I'm still too close to the buildplate but there is pla flowing.
    Again much thanks,
    Bill in colorado
