Time scale under temperature chart?
could we get a timescale added under the temperature chart in DWC?
I've also wanted this for some time.
+1 for this request.
Actually I played with this a bit before but I found it too ugly to add to the official versions. What units would you like to see there? I can take a screenshot if you want and demonstrate what it would look like.
@chrishamm said in Time scale under temperature chart?:
Can't work on a screenshot at the moment but something in the shape of a grid. On the vertical axis the temperature, already there; on the horizontal time from 0 to X seconds (maybe zoomable). I would not work with absolute time stamps but just 0s 1s 2s .... 10s for example.
Maybe an oscilloscope screen is a good source for inspiration, with temperature instead of voltage of course.
One of the features I miss the most from Octoprint is the interactive temperature graph plugin. It allowed for scrolling the graph back to see the history as well as zooming in on a portion of the graph. It also allowed you to send the graph data to a statistical spreadsheet view where you could do other work on it with a single click.
https://plugins.octoprint.org/plugins/tempsgraph/
I'm not sure if something like that could be worked into the DWC.
Similar to what @Phaedrux said, I would already be very happy if the graph would provide a Octoprint-like mouse-over that shows the temperature at that position in the graph.
