    Wifi Module startup inconsistencies
    1089
    • gbiski
      gbiski last edited by
      When i start or reboot my duet wifi the WiFi module very often does not start at all (no blue light).
      If i reboot once or twice some times everything works fine.
      Any ideas what is happening ?
      thanks a lot
      George
      • patakopecek
        patakopecek last edited by
        I would say a defective duet/wifi chip, if it is original, send it back to get it replaced/repaired
          Please confirm which versions of the main and the WiFi firmware you are using.
          gbiski 2 Replies Last reply Reply Quote 0
          • gbiski
            gbiski @dc42 last edited by
            @dc42 Sorry for the late reply but I was away from home.
            The version is:
            Firmware Version: 2.0(RTOS) (2018-06-05b3)
            WiFi Server Version: 1.21
            Web Interface Version: 1.21.1
            • Iamturbo1978
              Iamturbo1978 last edited by
              I too am having problems with this. I only see it if I hit emergency stop, and force the Duet to reboot. The only way I can get it back working again, is to either power reset, or push the on board reset button. I had the issue on firmware version 2.02, but I just upgraded to RC4 and I have not tested the issue yet.
                Have you seen this?
                https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors
                • gbiski
                  @dc42 Do i have to upgrade the firmware ?
                    If you upgrade the main firmware to 2.02RC4 then the automatic wifi reconnection feature may help you. However, I suspect that the wifi signal strength at the Duet's antenna is too low. Please read the wiki page that @Phaedrux linked to.
                    gbiski 1 Reply Last reply Reply Quote 0
                    • gbiski
                      @dc42 When the wifi signal is low the wifi module does not light up when booting ?
                        dc42 administrators @gbiski last edited by
                        @gbiski said in Wifi Module startup inconsistencies:
                        It should still flash while it is searching for networks.
                        • gbiski
                          @dc42 Mine does not. I have to reboot it 2-3 times to have it searching. It is weird.
                          • gbiski
                            Can i ask something not relevant to my issue ? I am thinking upgrading my CR10s with a Duet ethernet. I will use the same power supply of the CR10s. Can i connect directly the bed to the Duet or do i need a mosfet ? Or i must use the mosfet of the CR10s ?
                              When it has failed to start up, if you send M552 via USB (or PanelDue if you have one), what is the response?
                              • gbiski
                                @dc42 Hello,
                                It says:
                                WiFi module is idle
                                  Please post yor config.g file.
                                  • gbiski
                                    gbiski @dc42 last edited by dc42
                                    @dc42 Configuration file for Duet WiFi (firmware version 1.21)
                                    ; generated by RepRapFirmware Configuration Tool v2 on Fri Nov 23 2018 11:29:23 GMT+0200 (EET)
                                    M550 P"Dark Printer" ; Set machine name
                                    M551 P"3369: ; Set password
                                    M552 S1 ; Enable network
                                    M587 S"Dark" P"*****" I192.168.1.42 J192.168.1.1 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
                                    M586 P0 S1 ; Enable HTTP
                                    M586 P1 S0 ; Disable FTP
                                    M586 P2 S0 ; Disable Telnet
                                    M92 X160.00 Y160.00 Z800.00 E837.00 ; Set steps per mm
                                    M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
                                    M203 X18000.00 Y18000.00 Z600.00 E1500.00 ; Set maximum speeds (mm/min)
                                    M201 X1000.00 Y1000.00 Z50.00 E5000.00 ; Set accelerations (mm/s^2)
                                    M906 X1150.00 Y1150.00 Z1250.00 E1150.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                    M84 S30 ; Set idle timeout
                                    M208 X160 Y160 Z200 S0 ; Set axis maxima
                                    M574 Z1 S0 ; Set active low endstops
                                    M574 X1 Y2 S1 ; Set active high endstops
                                    M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
                                    G31 P500 X0 Y0 Z1.9 ; Set Z probe trigger value, offset and trigger height
                                    M557 X0:0 Y0:0 S20 ; Define mesh grid
                                    M305 P0 T100000 B3950 R4700 ; Set thermistor + ADC parameters for heater 0
                                    M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                                    M563 P0 D0 H1 ; Define tool 0
                                    ; Automatic power saving
                                    M911 S10 R11 P"M911 S10 R11 P”M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                                      I suggest you remove the M587 command from config.g. It should only be sent when setting up the connection, not every time you start up. Leaving it in there is also a security hazard.
                                      • gbiski
                                        @dc42 Hello,
                                        I removed the M587.
                                        It is much better but again not completed solved. In the 70% of the cases bow I do not need to reboot.
                                        In addition (not because removing the M587) I have some times disconections from the http during operation. When this happens I have to just reconnect by refreshing the page and or hitting reconnect but more rarely to reboot the duet in order to gain again wifi connectivity.
                                          Try upgrading to main firmware 2.02RC4 and DWC 1.22.5. The automatic retries may solve the remaining 30%.
