    Smart Effector on Corexy...
    14
    1595
    • flopo76
      flopo76 last edited by
      0_1542320490180_20181115_231705.jpg or on0_1542320535271_20181115_231710.jpg
      Smart effector on the corexy machine.
      Work in progress...
      • gmedlicott
        gmedlicott last edited by
        My first impression was, why? But now I'm thinking if DC42 designed a Core-XY optimized form factor version (smaller square say)...
        • RCarlyle
          RCarlyle last edited by
            We could do a rectangular one, perhaps 80mm x 40mm, with the mounting points on the short edges. Would that be better for mounting on a CoreXY printer?
            Dougal1957 bartolomeus madhunm timcurtis67 4 Replies Last reply Reply Quote 0
            • Dougal1957
              Dougal1957 @dc42 last edited by
              @dc42 Yes please David would love one of them for mine will make my mounting much easier. When can I have one to test 😉
              Doug
              • bartolomeus
                bartolomeus @dc42 last edited by
                @dc42 could you go smaller than 80mm? That's still quite wide.
                • madhunm
                  madhunm @dc42 last edited by
                  @dc42 said in Smart Effector on Corexy...:
                  I was looking at the design files the other day and have been meaning to ask this question: is the force sensor designed like a PCB printed strain gauge?
                    dc42 administrators @bartolomeus last edited by
                    @bartolomeus said in Smart Effector on Corexy...:
                    The Smart Effector has about 12 sq cm of strain gauge traces (less the hole for the hot end), plus another 12 sq cm of circuitry and connectors. We can't really reduce that. So we need an area of around 24 sq cm plus a little extra for mounting holes. Maybe we could make it 70mm wide, but not much narrower than that.
                    Dougal1957 1 Reply Last reply Reply Quote 0
                    • gmedlicott
                      Count me interested in one as well. I'll beta test like Doug! I'm OK with 70-80mm length as my carriage is 80mm long.
                      • Dougal1957
                        @dc42 80mm will be fine for me especially if you can get the connectors along the long edge that would make for an easier mounting!
                        Doug
                        • flopo76
                          works very well....
                          • Dougal1957
                            Dougal1957 @flopo76 last edited by
                            @flopo76 would you care to share the design files for your carriage (I assume it fits to a MGN12 rail at least that's what it looks like)
                            also do you have any issues with the offset causing a wider than normal range of repeatability of the sensor?
                            Doug
                            • flopo76
                              flopo76 last edited by flopo76
                              I made a new version, with all connectors on top of the PCB, to make more space for the fans. I also did a hotend with the lathe. It works great. I load everything on Thingiverse when everything is ready.
                              0_1542457271483_20181117_131337.jpg0_1542457224662_20181117_131334.jpg 0_1542457335731_20181117_131357.jpg
                              Youtube video: https://www.youtube.com/watch?v=-ax3ZA9E3ZA&feature=youtu.be
                              • timcurtis67
                                timcurtis67 @dc42 last edited by
                                I will buy one if you build them.
