    Password prompt from web gui after AJAX error
    • dudmahn
      dudmahn last edited by
      I've been using my Duet WiFi for a few weeks now, and it's working great. However, I've noticed that sometimes when I come back after a print, the web GUI is reporting that an AJAX error has occurred. I'm not positive, but I believe the AJAX error is generally associated with a WiFi glitch (disconnect/reconnect). When I attempt to connect to the web GUI (pressing the Connect button), or refresh the web page, I get a password prompt. I don't usually see this prompt when logging in. The prompt looks like this:
      Password Required
      Please enter your password
      Cancel Verify
      The only way I can get beyond this prompt is to power cycle the Duet WiFi board. Any idea about what might be going on here?
      In case it matters, I have a PanelDue connected to the board as well.
      Firmware Name: RepRapFirmware for Duet WiFi
      Firmware Version: 1.15b (2016-08-25)
      WiFi Server Version: 1.02
      Web Interface Version: 1.12-RC1
      • T3P3Tony
        i assume yo have not set a different password from the default in config.g?
        Duet Hardware Designer
        www.duet3d.com
          Older versions of DWC tend to report connection errors as password required. I suggest you upgrade to the latest versions of all 3 components.
          • dudmahn
            @T3P3Tony:
            No, I haven't changed the password in config.g.
            • dudmahn
              @dc42:
              I'll upgrade everything and see if that helps.
