    SOLVED PanelDue 7i screen has a yellow tint.
    PanelDue
    1084
    • jleadbetter
      jleadbetter last edited by
      Got my Duet WiFi and PanelDue 7i yesterday. Hooked it up with the supplied 4 pin cable and a couple of 10 pin ribbon cables from my RAMPS setup and the screen is very yellow. Does it whether it's connected to the Duet or just powered via USB. Thoughts? Anyone seen this before? Bad board?
        Please go to the Setup page on Panel Due. There are colour gradients on that page to help check whether the colours are correct.
        • jleadbetter
          jleadbetter last edited by jleadbetter
          Do you have a link? Searched high and low and can't find anything referencing colour gradients.
          In the meantime I thought I'd share what the screen actually looks like.
          https://photos.app.goo.gl/UEPohRJANswcbyBD7
          • elmoret
            elmoret last edited by
            He's referring to the Setup tab, the lower right button in your photo.
            • jleadbetter
              Thank you!
              https://photos.app.goo.gl/c9HXPeZfxUMvVUUe6
                Yes, those colours are completely wrong. Please ask for it to be replaced. [Note to repairer: check for shorts between adjacent pins of the SSD1963 chip, or the ATSAM4S4B.] This is what it should look like.
                  I am wondering whether your PanelDue hardware is OK but it has been flashed with the wrong firmware binary.
                  • max93093
                    max93093 last edited by
                    @dc42 hi i just was experiencing a "yellow screen" which quickly became a solid white screen with lines on it. currently contacting filastruder as it's only been on the machine for about a month (purchased back in october at the beginning of the build) it seems fiddling with firmware was what messed it up but i'm unable to get it back operating.
                    • BPisLife
                      BPisLife last edited by
                      I had this issue also. In my case I had flashed it with the wrong firmware and not the 7.0i firmware.
