    RepRapFirmware 2.02RC4 released
    Firmware installation
    18
    72
    8.3k
    • MoS-tekknixundefined
      MoS-tekknix
      This post is deleted!
      • garyd9undefined
        garyd9 @dc42
        @dc42 said in RepRapFirmware 2.02RC4 released:
        @garyd9 said in RepRapFirmware 2.02RC4 released:
        With RC4, DWC is still often reporting an incorrect current layer.   In the attached/linked gcode file, there are 70 layers.   DWC is reporting that layer 2 of 70 is currently being printed for many layers (I'm currently printing the 6th layer and it's still showing 2 of 70.)
        I think this line, just before the "end of prime line" comment, is confusing the firmware:
        G1 X34.441 Y-145.764 Z4.2 E0 F9000
        Because it contains both XY movement and extrusion, the firmware classifies it as a printing move, and it therefore thinks that you have completed the print up to Z=4.2. It is waiting for an extruding move at a greater Z height before it counts another layer.
        How can I inform the firmware that a certain block of gcode is a preamble and should be ignored for layer calculation? While I can certainly "fix" that last line of the prime/wipe script, there's a similar line near the beginning of the script that might also cause the same issue.
        Even if I start my "prime/wipe" line at 0.2mm, it sounds like it'd still confuse the firmware (but at least to a lesser degree) as it actually performs a movement while extruding.
        BTW, that "prime line" script was something I copied from another person without actually examining. Looking at it now, the last several lines of it seem... odd. While there's nothing technically wrong with specifying "E0" with G1, or a G1 that "moves" to the exact same X and Y as the previous G1, I do want to clean that up.
        It won't fix this problem, but at least the script would make more sense to me.
        "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
        • fcwiltundefined
          fcwilt @garyd9
          I cannot see any reason to you need to be doing a move with extrusion for "prime/wipe" purposes.
          What is your reasoning?
          Thanks.
          garyd9undefined 1 Reply Last reply Reply Quote 0
          • insertnamehereundefined
            insertnamehere @dc42
            We had a report of this one or two RC versions ago, but I was unable to reproduce it. I'll test it again. Please post your pause.g file here.
            I'll try to make it happen again and see if I can give you a step by step.
            M83 ; relative extruder moves
            G1 E-10 F3600 ; retract 10mm of filament
            G91 ; relative positioning
            G1 Z3 F360 ; lift Z by 3mm
            G90 ; absolute positioning
            G1 X0 Y250 F6000 ; go to X=0 Y=250
            • garyd9undefined
              garyd9 @fcwilt
              @fcwilt said in RepRapFirmware 2.02RC4 released:
              Extruding a prime line (for prime/wipe) involves extruding filament while moving (as if printing a thick layer of filament.) The next step is to move back over the extruded filament while not extruding.
              fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt @garyd9
                Interesting. I've not heard of that before. The priming code I've seen just extrudes a small amount with no movement.
                Thanks for the feedback.
                • Danalundefined
                  Danal
                  FWIW, I've found a "prime line" deposited on the glass, "off to one side", to be a great help in getting certain printers to succeed with the first layer, while NOT having a blob/defect on the bottom of the part (from priming "in the air" and the prime falling or being squished).
                  • fcwiltundefined
                    fcwilt @Danal
                    @danal said in RepRapFirmware 2.02RC4 released:
                    I just print a few lines of "skirt" which gives me a chance to verify that all should be well and I can tweak the Z height if needed.
                    Since this is handled by the slicer it doesn't cause any issues.
                    Danalundefined 1 Reply Last reply Reply Quote 0
                      Phaedrux Moderator @garyd9
                      Is that really necessary? I get excellent results with this prime line gcode.
                      G90 			; Absolute positioning
                      G1 X1 Y270 F6000 		; Move to front left corner
                      M400 			; clear movement buffer
                      M116 			; Wait for temps
                      G1 Z0.3 F100		; Move Z to prime height
                      G91 			; Relative positioning
                      M83 			; Relative extrusion
                      G1 X40 E10 F300 	; Prime nozzle
                      G10			; Retract
                      G1 Y-1 X1 F10000 	; Wipe nozzle
                      ; Move to first layer Z height and start skirt
                      • garyd9undefined
                        garyd9 @Phaedrux
                        @phaedrux said in RepRapFirmware 2.02RC4 released:
                        I don't understand how the line commented with "wipe nozzle" is wiping anything. You have a 40mm line along the X axis, and then the "wipe nozzle" commented line just moves the nozzle away from the extruded line at a 45 degree angle.
                        Usually, "wipe" actions push the hot nozzle through or against something else (such as slightly cooled extruded plastic.) Doing this usually cleans the nozzle as any debris on the nozzle will stick to the already extruded plastic. (Of course, if you have poor build plate adhesion, the "wipe" can result in a big glob of plastic sticking to the nozzle instead.)
                        As far as it being necessary... No, it's technically not. However, I do MANY things every single print that aren't strictly necessary, such as cleaning the nozzle with a wire brush, wiping it with something soft that's also heat resistant (such as leather or silicon), auto-calibrating before each print, using steel wool on my PEI sheet followed by acetone (or windex for PETG), etc.
                        While there are flaws in the script (such as extruding 0mm and X/Y movements that result in no movement) that might be confusing the firmware, I hope that any discussion about that script in this particular thread could be constrained to the inaccurate information displayed in DWC (and how to revise the script to work around the confusion) while retaining the function of the script.
                        I'd be happy to discuss the pros/cons of prime/wipe scripts (and any particular implementation) in another thread.
                          dc42 administrators @insertnamehere
                          @insertnamehere said in RepRapFirmware 2.02RC4 released:
                          Previously I've been using M226 to pause prints by editing it into the gcode. I've just tried that on RC4 and although it paused, it also locked up and I was unable to continue the print. A power off was the only way to reset.
                          M600 was doing the same thing in RC3.
                          Anybody else experiencing this?
                          I'm sorry, I can't reproduce this. I inserted five M226 commands into a GCode file, and it's working as it should.
                          Do you have anything unusual in your pause.g file?
                            I can post a video if you like, but basically the "wipe" part just pulls the nozzle out of the extruded line of plastic quickly, leaving whatever was attached to the nozzle attached to the line and the nozzle is clean.
                            By asking if it was necessary I merely meant perhaps there is another way to achieve what you're after. My example was just showing one such way.
                            • garyd9undefined
                              garyd9
                              "Warning: motor phase A may be disconnected reported by driver(s) 2"
                              (I thought this was resolved in RC2 or RC3??):
                              I think it's happening during the very slow Z movements when doing G32 probing, but I can't be sure. I know it happens sometime between issuing G32 and getting the results on the paneldue console page. On this machine, I'm using the manual bed leveling assistant (that tells me how far to turn each of three leveling screws.)
                              I'm using a BLTouch on this printer (with probe type 5 that always worked for me, so I never changed to the BLTouch dedicated probe type.)
                              Here's everything in config.g related to movement or bed leveling:
                              M350 X16 Y16 Z16 E16:16 I1
                              M92 X93.91 Y93.84 Z401.0 E103.287:102.287
                              M566 X480 Y480 Z300 E1200:1200
                              M203 X12000 Y12000 Z2000 E3600:3600
                              M201 X750 Y750 Z150 E2000:2000
                              M906 X810 Y810 Z300 E810:810 I30
                              M558 P5 X0 Y0 Z1 H5 F100 T6000 A3 B1
                              G31 X-73.2 Y-0.8 Z1.17 P25
                              M671 X0.0:-51:48 Y-68.2:66.0:66.0 P0.5
                              // homeall.g
                              M280 P3 S160 I1 ; reset any bltouch alarm and pull up the pin
                              T1 P0                 ; X must be homed relative to the right nozzle.  P0 prevents any tool change macros
                              G1 S2 Z5 F6000        ; lower HBP relative to current position
                              G1 S1 X266 Y155 F6000 ; move quickly to X and Y axis endstops and stop there (first pass)
                              G1 S2 X-5 Y-5 F6000   ; go back a few mm on all axis
                              G1 S1 X266 Y155 F360  ; move slowly to X and Y axis endstops once more (second pass)
                              G90		; back to absolute
                              G92 X151 Y75	; set X and Y
                              G1 X73.2 Y-67.4 F6000  ; position the probe over the front/center screw adjustment point (offsetting from T1)
                              M401			; deploy the probe
                              G1 S1 Z-155 F6000	; quickly move Z down, stopping at the probe
                              G1 S2 Z5 F1200		; immediately move the nozzle 5mm away from the build plate
                              M401			; make sure the probe is deployed still
                              G30			; slowly probe at the current position and set Z to the trigger height
                              M402			; retract the probe
                              // bed.g
                              G29 S2; clear any heightmaps
                              ; Probe the bed at 3 points
                              M402 ; retract probe
                              G28 ; home
                              G90 ; absolute moves
                              G1 Z5 ; get the bed out of the way so the probe can deploy
                              G30 P0 X0.0 Y-68.2 Z-99999
                              G30 P1 X-51 Y66.0 Z-99999
                              G30 P2 X48 Y66.0 Z-99999 S3
                              Edit: The board is a Duet Ethernet 1.02.
                              • Danalundefined
                                Danal @fcwilt
                                Skirt works when it is a choice.
                                Sometimes, NOT having a skirt is crucial to the "bottom to side" transition. Particularly on single-wall, zero infill, parts.
                                • fcwiltundefined
                                  fcwilt @Danal
                                  I have no idea what that means.
                                  AlexLinundefined 1 Reply Last reply Reply Quote 0
                                  • AlexLinundefined
                                    AlexLin @fcwilt
                                    @fcwilt maybe confusing skirt with brim....
                                    • fcwiltundefined
                                      fcwilt @AlexLin
                                      @alexlin said in RepRapFirmware 2.02RC4 released:
                                      That may be the case.
                                      Thanks.
                                        dc42 administrators @garyd9
                                        Can you try to pin this down? In RC4 I increased the minimum motor speed below which the open-load status from the drivers is ignored; so that message shouldn't be generated at low speeds.
                                        Also, please use M115 to double check that you are running 2.02RC4.
                                        garyd9undefined 3dmntbighkerundefined 2 Replies Last reply Reply Quote 0
                                        • Danalundefined
                                          Danal @fcwilt
                                          Thanks.
                                          Yikes, correct!!! I was confusing skirt with brim...
                                          So, let me change it to:
                                          If you have room for a skirt, sure, that works. There may be circumstances where there is room for a prime line, but not for a standard full skirt.
                                          • garyd9undefined
                                            garyd9 @dc42
                                            M115
                                            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02RC4(RTOS) ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2018-11-18b5
                                            As for pinning it down, I'll try this evening (US Eastern time.) Do you have any suggestions on how I could go about doing that? Just perform manual Z movements via "G1 Zxx F100"?
                                            It's difficult to isolate via G32, as the message doesn't appear until the bed.g is completed, so it might be happening in the very first move that G32 performs, it it might be the very last... there's no way to really tell (that I'm aware of.)
                                            As well, it doesn't happen every time I level the bed, and I believe it's more frequent the first time I level the bed after transitioning from standby power (5VDC via USB) to full power (24VDC via VIN) using the ATX controls.
