    RepRapFirmware 2.02RC4 released
    Firmware installation
    18
    72
    8.2k
      I can't think of any reason why you would need to change the bed.g file for the latest release. You should not need to have a tool selected. You do need to have homed X and Y as well as Z, so you might want to change the G28 Z command to just G28.
      BTW, M561 and G29 S2 do the same thing.
      Martin1454undefined 1 Reply Last reply Reply Quote 0
      • Martin1454undefined
        Martin1454 @dc42
        @dc42 Well, I get an "homing error" when the it is done probing the 3 points and returning to X0 Y0
        I home in my X and Y in the homeall.g and Z in bed.g
        Here is my home all:
        M400; make sure everything has stopped before we make changes
        M574 X1 Y1 S3		;
        M913 X30 Y30 		; XY motors to 30% current
        M915 X Y H400 S3 R0 F0	; set X and Y to sensitivity , do nothing when stall, unfiltered
        ; X axis home
        G91			; use relative positioning
        G1 Z5 F6000 S2    ; lift Z relative to current position
        G1 S1 X-405 F6000 ; move quickly to X axis endstop and stop there (first pass)
        G1 X5 F6000       ; go back a few mm
        G1 S1 X-405 F4000  ; move slowly to X axis endstop once more (second pass)
        ; Y axis home
        G1 S1 Y-305 F6000 ; move quickly to Y axis endstop and stop there (first pass)
        G1 Y5 F6000       ; go back a few mm
        G1 S1 Y-305 F4000  ; move slowly to Y axis endstop once more (second pass)
        G90               ; absolute positioning
        M913 X100 Y100; motor currents back to 100%
        ; Z-axis
        M561                     ; Clear any bed transform
        G32                      ; Start 3-point probe sequence - Bed.g
        ;M375 P"bareplate.csv"    ; Load heightmap
        G1 Z20.0 F6000           ; Move Z to 20
        G1 X5 Y5    		 ; Move Head to front left
        • resamundefined
          resam
          @deckingman said in RepRapFirmware 2.02RC4 released:
          I do still get a short "double blip" of the hot end fan when booting but it's much much shorter and the overall boot up time seems to be faster.
          I think I always had this double blip - see my video (listen to the audio!)
          https://www.dropbox.com/s/tz5n8j4xaparicd/fan-double-blip.mp4?dl=0
          Also take a look at my reconnect time of the PanelDue.
          DuetWifi 2.02RC4 + PanelDue 1.22.1
          @dc42 is this normal behaviour - or do you suspect something is wrong?
            dc42 administrators @resam
            @resam said in RepRapFirmware 2.02RC4 released:
            Do the heater LEDs on the Duet flash twice too?
            • resamundefined
              resam
              @dc42 said in RepRapFirmware 2.02RC4 released:
              As long as I press the reset button on the DuetWifi, the hotend fan turns on.
              When I release the reset button, the fan is still on for a second or so, before it goes off, and then turns on for a second before finally turning off.
              Both LED E0 HEAT and LED E1 HEAT flash on a single time.
              • sigxcpuundefined
                sigxcpu
                My LEDs (P2) flash once, the thermostatic fan (P1) "flashes" twice. I don't hear the pump (P0) "flashing" at all.
                  That's all as expected. Fan 1 is on by default, in case you reset the machine or upload firmware to it while the hot end is hot and need to be cooled. In 2.02RC5 the heater LEDs won't flash.
                  • MoS-tekknixundefined
                    MoS-tekknix
                    This post is deleted!
                    • garyd9undefined
                      garyd9 @dc42
                      @garyd9 said in RepRapFirmware 2.02RC4 released:
                      With RC4, DWC is still often reporting an incorrect current layer.   In the attached/linked gcode file, there are 70 layers.   DWC is reporting that layer 2 of 70 is currently being printed for many layers (I'm currently printing the 6th layer and it's still showing 2 of 70.)
                      I think this line, just before the "end of prime line" comment, is confusing the firmware:
                      G1 X34.441 Y-145.764 Z4.2 E0 F9000
                      Because it contains both XY movement and extrusion, the firmware classifies it as a printing move, and it therefore thinks that you have completed the print up to Z=4.2. It is waiting for an extruding move at a greater Z height before it counts another layer.
                      How can I inform the firmware that a certain block of gcode is a preamble and should be ignored for layer calculation? While I can certainly "fix" that last line of the prime/wipe script, there's a similar line near the beginning of the script that might also cause the same issue.
                      Even if I start my "prime/wipe" line at 0.2mm, it sounds like it'd still confuse the firmware (but at least to a lesser degree) as it actually performs a movement while extruding.
                      BTW, that "prime line" script was something I copied from another person without actually examining. Looking at it now, the last several lines of it seem... odd. While there's nothing technically wrong with specifying "E0" with G1, or a G1 that "moves" to the exact same X and Y as the previous G1, I do want to clean that up.
                      It won't fix this problem, but at least the script would make more sense to me.
                      • fcwiltundefined
                        fcwilt @garyd9
                        I cannot see any reason to you need to be doing a move with extrusion for "prime/wipe" purposes.
                        What is your reasoning?
                        garyd9undefined 1 Reply Last reply Reply Quote 0
                        • insertnamehereundefined
                          insertnamehere @dc42
                          We had a report of this one or two RC versions ago, but I was unable to reproduce it. I'll test it again. Please post your pause.g file here.
                          I'll try to make it happen again and see if I can give you a step by step.
                          M83 ; relative extruder moves
                          G1 E-10 F3600 ; retract 10mm of filament
                          G91 ; relative positioning
                          G1 Z3 F360 ; lift Z by 3mm
                          G1 X0 Y250 F6000 ; go to X=0 Y=250
                          • garyd9undefined
                            garyd9 @fcwilt
                            @fcwilt said in RepRapFirmware 2.02RC4 released:
                            Extruding a prime line (for prime/wipe) involves extruding filament while moving (as if printing a thick layer of filament.) The next step is to move back over the extruded filament while not extruding.
                            fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                            • fcwiltundefined
                              fcwilt @garyd9
                              Interesting. I've not heard of that before. The priming code I've seen just extrudes a small amount with no movement.
                              Thanks for the feedback.
                              • Danalundefined
                                Danal
                                FWIW, I've found a "prime line" deposited on the glass, "off to one side", to be a great help in getting certain printers to succeed with the first layer, while NOT having a blob/defect on the bottom of the part (from priming "in the air" and the prime falling or being squished).
                                • fcwiltundefined
                                  fcwilt @Danal
                                  @danal said in RepRapFirmware 2.02RC4 released:
                                  I just print a few lines of "skirt" which gives me a chance to verify that all should be well and I can tweak the Z height if needed.
                                  Since this is handled by the slicer it doesn't cause any issues.
                                    Phaedrux Moderator @garyd9
                                    Is that really necessary? I get excellent results with this prime line gcode.
                                    G90 			; Absolute positioning
                                    G1 X1 Y270 F6000 		; Move to front left corner
                                    M400 			; clear movement buffer
                                    M116 			; Wait for temps
                                    G1 Z0.3 F100		; Move Z to prime height
                                    G91 			; Relative positioning
                                    M83 			; Relative extrusion
                                    G1 X40 E10 F300 	; Prime nozzle
                                    G10			; Retract
                                    G1 Y-1 X1 F10000 	; Wipe nozzle
                                    ; Move to first layer Z height and start skirt
                                    • garyd9undefined
                                      garyd9 @Phaedrux
                                      @phaedrux said in RepRapFirmware 2.02RC4 released:
                                      I don't understand how the line commented with "wipe nozzle" is wiping anything. You have a 40mm line along the X axis, and then the "wipe nozzle" commented line just moves the nozzle away from the extruded line at a 45 degree angle.
                                      Usually, "wipe" actions push the hot nozzle through or against something else (such as slightly cooled extruded plastic.) Doing this usually cleans the nozzle as any debris on the nozzle will stick to the already extruded plastic. (Of course, if you have poor build plate adhesion, the "wipe" can result in a big glob of plastic sticking to the nozzle instead.)
                                      As far as it being necessary... No, it's technically not. However, I do MANY things every single print that aren't strictly necessary, such as cleaning the nozzle with a wire brush, wiping it with something soft that's also heat resistant (such as leather or silicon), auto-calibrating before each print, using steel wool on my PEI sheet followed by acetone (or windex for PETG), etc.
                                      While there are flaws in the script (such as extruding 0mm and X/Y movements that result in no movement) that might be confusing the firmware, I hope that any discussion about that script in this particular thread could be constrained to the inaccurate information displayed in DWC (and how to revise the script to work around the confusion) while retaining the function of the script.
                                      I'd be happy to discuss the pros/cons of prime/wipe scripts (and any particular implementation) in another thread.
                                        dc42 administrators @insertnamehere
                                        @insertnamehere said in RepRapFirmware 2.02RC4 released:
                                        Previously I've been using M226 to pause prints by editing it into the gcode. I've just tried that on RC4 and although it paused, it also locked up and I was unable to continue the print. A power off was the only way to reset.
                                        M600 was doing the same thing in RC3.
                                        Anybody else experiencing this?
                                        I'm sorry, I can't reproduce this. I inserted five M226 commands into a GCode file, and it's working as it should.
                                        Do you have anything unusual in your pause.g file?
                                          I can post a video if you like, but basically the "wipe" part just pulls the nozzle out of the extruded line of plastic quickly, leaving whatever was attached to the nozzle attached to the line and the nozzle is clean.
                                          By asking if it was necessary I merely meant perhaps there is another way to achieve what you're after. My example was just showing one such way.
                                          • garyd9undefined
                                            garyd9
                                            "Warning: motor phase A may be disconnected reported by driver(s) 2"
                                            (I thought this was resolved in RC2 or RC3??):
                                            I think it's happening during the very slow Z movements when doing G32 probing, but I can't be sure. I know it happens sometime between issuing G32 and getting the results on the paneldue console page. On this machine, I'm using the manual bed leveling assistant (that tells me how far to turn each of three leveling screws.)
                                            I'm using a BLTouch on this printer (with probe type 5 that always worked for me, so I never changed to the BLTouch dedicated probe type.)
                                            Here's everything in config.g related to movement or bed leveling:
                                            M350 X16 Y16 Z16 E16:16 I1
                                            M92 X93.91 Y93.84 Z401.0 E103.287:102.287
                                            M566 X480 Y480 Z300 E1200:1200
                                            M203 X12000 Y12000 Z2000 E3600:3600
                                            M201 X750 Y750 Z150 E2000:2000
                                            M906 X810 Y810 Z300 E810:810 I30
                                            M558 P5 X0 Y0 Z1 H5 F100 T6000 A3 B1
                                            G31 X-73.2 Y-0.8 Z1.17 P25
                                            M671 X0.0:-51:48 Y-68.2:66.0:66.0 P0.5
                                            // homeall.g
                                            M280 P3 S160 I1 ; reset any bltouch alarm and pull up the pin
                                            T1 P0                 ; X must be homed relative to the right nozzle.  P0 prevents any tool change macros
                                            G1 S2 Z5 F6000        ; lower HBP relative to current position
                                            G1 S1 X266 Y155 F6000 ; move quickly to X and Y axis endstops and stop there (first pass)
                                            G1 S2 X-5 Y-5 F6000   ; go back a few mm on all axis
                                            G1 S1 X266 Y155 F360  ; move slowly to X and Y axis endstops once more (second pass)
                                            G90		; back to absolute
                                            G92 X151 Y75	; set X and Y
                                            G1 X73.2 Y-67.4 F6000  ; position the probe over the front/center screw adjustment point (offsetting from T1)
                                            M401			; deploy the probe
                                            G1 S1 Z-155 F6000	; quickly move Z down, stopping at the probe
                                            G1 S2 Z5 F1200		; immediately move the nozzle 5mm away from the build plate
                                            M401			; make sure the probe is deployed still
                                            G30			; slowly probe at the current position and set Z to the trigger height
                                            M402			; retract the probe
                                            // bed.g
                                            G29 S2; clear any heightmaps
                                            ; Probe the bed at 3 points
                                            M402 ; retract probe
                                            G28 ; home
                                            G90 ; absolute moves
                                            G1 Z5 ; get the bed out of the way so the probe can deploy
                                            G30 P0 X0.0 Y-68.2 Z-99999
                                            G30 P1 X-51 Y66.0 Z-99999
                                            G30 P2 X48 Y66.0 Z-99999 S3
                                            Edit: The board is a Duet Ethernet 1.02.
