    My printer
    • josegerdes
      josegerdes last edited by
      Guys my stall detection dont work, i am using duet for 6 mounths and i couldnt make it work. Can u guys help me and check if i can make my configs better. And the power protection not working to.. If i poweroff the printer then turn on in a middleprint can i restart when it stopped?
      G90
      M83
      M667 S1
      M550 P JOSE ARTHUR PRINTER
      M552 S1
      M587 S"ASSJA1" P"291005gus"
      M586 P0 S1
      M586 P1 S0
      M586 P2 S0
      M569 P0 S1
      M569 P1 S1
      M569 P2 S1
      M569 P3 S0
      M350 X16 Y16 Z16 E16 I1
      M92 X80 Y80 Z800 E100
      M566 X900 Y900 Z10 E120
      M203 X12000 Y12000 Z300 E3000
      M201 X1000 Y1000 Z100 E5000
      M906 X1000 Y1000 Z1000 E1000 I60
      M84 S30
      M208 X0 Y0 Z0 S1
      M208 X285 Y235 Z250 S0
      M574 X1 Y1 S1
      M574 Z1 S2
      M558 P9 H4 F600 T5000 X0 Y0 Z1
      M307 H3 A-1 C-1 D-1
      G31 X25 Y0 Z1.9 P25
      M557 X25:205 Y25:165 S50
      M305 P0 T100000 B3988 C0 R4700
      M143 H0 S120
      M305 P1 T100000 B4725 C0 R4700
      M143 H1 S240
      M307 H1 A340.0, C140.0, D5.5 S0.3
      M557 X25:275 Y25:275 S20
      M106 P0 S1 I0 F500 H-1
      M106 P1 S1 I0 F500 H-1
      M106 P2 S1 I0 F500 H-1
      M563 P0 D0 H1
      G10 P0 X0 Y0 Z0
      G10 P0 R0 S0
      ; Automatic power saving
      M911 S20.0 R40.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
      M915 X Y S5 F0 H200 R3
      M501
      T0
        Please explain more precisely what problems you are having.
        1. Stall detection: in what way is it not working? What sort of printer is it? Have you followed the instructions at https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing?
        2. Resume after power fail: in what way is it not working? Have you worked through https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure? Does it create a resurrect.g file in /sys on the SD card when you turn the power off? Have you set up the resurrect-prologue.g file?
