    Filament config
    1482
    • Iamturbo1978
      Iamturbo1978 last edited by
      Hello everyone,
      I'm just starting with the filament feature. I have a working load, unload, and config macros. I noticed that after a power down and restart, the filament is loaded under the tool 0, like is should, but the config does not load. with in my filament config macro, I have it set up to clear any baby stepping, then do -0.10mm baby stepping. If I unload and load the filament, the config macro runs like it should, but after power down, the config macro doesn't load. Is there something I am missing, or is there something I should be doing to make the filament config macro run after power up?
      Thanks
      • CaiJonas
        CaiJonas last edited by
        I just join this because I have similiar problems. In my case the filament config does not work. First it worked perfect and I used the filaments config to set up diffrent pressure advance settings but now it doesn' work any more. I don't know what changed 😞
        Best Regards
        Cai
        • chrishamm
          chrishamm administrators last edited by
          This is behaviour is intentional because the tool of the corresponding filament has to be selected in order for the config macro to work. See M703 for more information about how to run filament configs manually (https://reprap.org/wiki/G-code#M703:Get_Board_Type.2F_Configure_Filament).
          Duet software engineer
          CaiJonas Iamturbo1978 2 Replies Last reply Reply Quote 0
          • CaiJonas
            CaiJonas @chrishamm last edited by
            @chrishamm
            I did add M703 in the tpost*.g file but that didn't change anything. Or do I have to put it somewhere else?
            timcurtis67 1 Reply Last reply Reply Quote 0
            • Iamturbo1978
              Iamturbo1978 @chrishamm last edited by
              @chrishamm thank you so much for the reply. It makes total sense why not to load the config automatically. I now understand what I need to do. Thank you.
              • timcurtis67
                timcurtis67 @CaiJonas last edited by
                @caijonas said in Filament config:
                @chrishamm
                What firmware version are you using? You must use 2.02 or newer to use the M703 feature.
                See https://duet3d.dozuki.com/Wiki/GCode#Section_M703_Configure_filament
                CaiJonas 1 Reply Last reply Reply Quote 0
                • CaiJonas
                  CaiJonas @timcurtis67 last edited by
                  @timcurtis67
                  I am using the latest one --> 2.02RC4
                  chrishamm 1 Reply Last reply Reply Quote 0
                  • chrishamm
                    chrishamm administrators @CaiJonas last edited by
                    @caijonas Be aware that no tool change macros are run if you select the tool in config.g or if you don't have the axes homed at the time the T-code is processed.
                    • genghisnico13
                      genghisnico13 last edited by
                      I added M703 to the start macro that is called in the start gcode.
                      I believe there is room for improvement by loading the config automatically but this works.
                      • CaiJonas
                        I Just added M703 into the start gcode of my slicer. Now it works. Thank you.
                        Best richtige
                        Cai
