Error: short-to-ground on drivers 0 1
I just got Duet Ether and wiring step motor on Driver 0 1 2 . I found that I wired wrong step motor , it 's shake when try to move. I try to switch wire and found the Error: short-to-ground on drivers 0 1. So I unplug all step motor and try to move x and y , the Error: short-to-ground on drivers 0 1 still appear. My driver short circuit ?Thank.
Can you explain in what way you had the motors wired incorrectly to the outputs on the Duet?
First ,I upgrade board form X5S board and buy new wire, I forgot to checked new wire connect to step motor(I test phase form old wire) . So I conncect with new wire.. All motor was turn left and right (shaking)when I move each x y z. I try to switch wire and test on Z. Finally, I can move the motor correctly for Z and I try to connect the correct wire to x and move. Motor was shaking and show the error as above" Error: short-to-ground on drivers 0 1" . I try to switch wire agian but still turn left and right(shaking) when I move X. For Y was same too.
Hi @Parkin,
User wiring error isn't covered by the warranty. However, we've decided to offer to replace your board with a refurbished board of the same revision, assuming it's a genuine UK-manufactured board bought from us or one of your distributors. Please see https://www.duet3d.com/warranty if you purchased directly from us, or contact your distributor. Refer to this thread in your communication.
Thank you very much. I will contact for replace for a refurbished board.
One more, do you have another program for buy new one with exchange old defect for discount?.
Thankyou.
@parkin please contact me directly info@duet3d.com for further warranty information.
