    Issues with M206, homing, leveling and probing
    • brunofportoundefined
      brunofporto
      After finishing building my new printer I starte to tune dimensions and macros of my old printer to the new.
      Both are coreXY but the dimensions limits changed a little.
      For a start, the X0 Y0 is offset -60mm for Y. So I used M206 Y-60 to set this offset.
      There is where my problems start!
      If I manually, gcode by gcode, apply my home all macro then it works flawlessly but I execute a G28 a G0 command to send the tool to X132 Y156 send it to X132 Y96!!!!! But only when executed from the G28 or home all DWC button. If I do line per line all goes well.
      The same happens for the G32, that I use with dual lead screws to correct the tilt of the bed. And so with the mesh commands of G29 - if I execute from the console the go to the correct XY coordinates. If I command from macros or system macros then they consider Y-60 as Y0 and the too goes out of the bed...
      What am I doing wrong?
      Firmware: 2.02RC3
      My config.g concerned part:
      M206 Y-60
      M208 X294 Y330 Z270 S0 ; Set axis maxima (needed to set the maxima as +60!!!!! why?? My real max is 270mm!!!!)
      My homeall.g
      ; homeall.g
      ; called to home all axes
      ; Home XY for Z homing
      G91 ; relative positioning
      G1 Z5 F200 S2 ; lift head relative to current position
      M400 ; make sure everything has stopped before we make changes
      M913 X50 Y50 ; set X Y motors to 50% of their normal current for homing
      M98 P"0:/sys/m_set_low_speeds.g" ; set lower Z speeds and accelerations
      ;==============Home X====================
      G1 S1 X-305 Y-335 F4800 ; move quickly diagonally to hit X or Y
      M400
      G1 X5 Y5 F1000 ; go back a few mm
      G1 S1 X-305 F4800 ; move quickly to X axis
      G1 X5 F1000 ; go back a few mm
      ;==============Home Y====================
      M400
      G1 S1 Y-335 F4800 ; move quickly to X axis endstop and stop there (first pass)
      G1 Y5 F1000 ; go back a few mm
      ;==============Home Z====================
      M400
      G90 ; absolute positioning
      G0 X132 Y156 F4000 ; move to center of bed
      ; Probe the bed
      M558 A1 F350 ; Set single probing at faster feed rate
      G30 ; Do a single probe to home our Z axis
      M558 A10 F100 ; Set tripple probing at slower feed rate
      G30 ; Probe again to get a more accurate position
      M98 P"0:/sys/m_set_normal_speeds.g" ; set normal Z speeds and accelerations
      M913 X100 Y100 ; set X Y motors to 100% of their normal current
        When you say the offset is -60mm for Y, do you mean that the Y homing switch triggers at Y=-60mm? If so then you should change the first M208 command to:
        M208 X0 Y-60 Z0 S1 ; Set axis minima
        and not use M206 at all. See https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin.
        YD14undefined 1 Reply Last reply Reply Quote 1
          brunofporto
          Thank you! Solved! 😄
          • YD14undefined
            YD14
            Greetings from YD.
            My problem is related to Delta homing.
            Whenever I try to home X, Y and Z axes, all the axes go 5 mm up and stop. I have tried all the possibilities that came to my mind. But all failed.
            1. Changed stepper motor with higher current rating and holding torque
            2. Tried all the possibilities with GCode and Mcode.
            So I hereby seek expert advice.
            My Config. g file is as follows:
            ; generated by RepRapFirmware Configuration Tool v2 on Tue Dec 04 2018 11:34:12 GMT+0530 (India Standard Time)
            G21 ; All units in millimeters
            M665 R105.6 L340 B85 H500 ; Set delta radius, diagonal rod length, printable radius and homed height
            M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
            M550 P"My Printer" ; Set machine name
            M552 S1 ; Enable network
            M586 P0 S1 ; Enable HTTP
            M586 P1 S0 ; Disable FTP
            M586 P2 S0 ; Disable Telnet
            M92 X100.00 Y100.00 Z100.00 E663.00 ; Set steps per mm
            M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; Set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; Set maximum speeds (mm/min)
            M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; Set accelerations (mm/s^2)
            M906 X1000.00 Y1000.00 Z1000.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 Z0 S1 ; Set minimum Z
            M574 X2 Y2 Z2 S1 ; Set active high endstops
            M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
            M557 R85 S20 ; Define mesh grid
            M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
            M563 P0 D0 H1 ; Define tool 0
            and my homedelta.g file is as follows:
            ; homedelta.g
            G1 S1 X500 Y500 Z500 F1800 ; move all towers to the high end stopping at the endstops (first pass)
            G1 X-5 Y-5 Z-5 F1800 S2 ; go down a few mm
            G1 S1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
            G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
            G1 X0 Y0 F6000 ; move X+Y to the centre
            Kindly help me to resolve the issue.
            • YD14undefined
              YD14
              Further my X and Y axes work perfectly fine as in for X+10 Y + 10, they both go up by 10 mm but for Z+5. Z axis comes down 5 mm. Code for this as follows:
              M569 P0 S0 ; Drive 0 goes backwards
              OR
              In either case, the same problem was observed.
              I tried changing the polarities only for Z. When i changed the polarities for Z, it was observed that during homing movement, X and Y went up but Z went down.
              Further I tried with Duet3D code that came with DUET wifi board in an SD card. WIth that also, the delta homing is not happening.
              So i am hereby messed up totally with Delta configuration, but my CoreXY is working nicely (at least printing).
              Kindly provide your valuable help for Delta printer configuration.
              • YD14undefined
                YD14 @dc42
                @dc42 Hello,
                Greetings from YD.
                ; homedelta.g
                OR
                  Phaedrux Moderator @YD14
                  @yd14 You should probably start a new thread for your problem rather than posting in a thread that is already marked as solved.
