    Tevo Black Widow and Duet WiFi
    • Klaus.Waelde
      Klaus.Waelde last edited by
      Hello everybody,
      Has anyone of you a basic setup for a stock black widow run on a duet wifi board. The y-axis works now but I cant replicate it to the x- and the z-axis. I'm looking for good start values for
      Set maximum instantaneous speed changes (mm/min)
      Set maximum speeds (mm/min)
      Set accelerations (mm/s^2)
      Set motor currents (mA) and motor idle factor in per cent
      Any help would be greatly appreciated.
      Thank you very much in advance
      Klaus
        See what you can find in here: https://forum.duet3d.com/search?term=tevo black widow&in=titlesposts&matchWords=all&sortBy=relevance&sortDirection=&showAs=posts
        • Veti
          Veti last edited by Veti
          i would start of with the tevo values for marlin
          https://tevo3dprinterstore.com/pages/black-widow-firmware
          # code block
          #define HOMING_FEEDRATE {50*60, 50*60, 4*60, 0}  // set the homing speeds (mm/min)
          // default settings
          #define DEFAULT_AXIS_STEPS_PER_UNIT   {160,160,3200,500}  // default steps per unit for Ultimaker
          #define DEFAULT_MAX_FEEDRATE          {300, 300, 5, 25}    // (mm/sec)
          #define DEFAULT_MAX_ACCELERATION      {1000,1000,100,10000}    // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
          #define DEFAULT_ACCELERATION          1000    // X, Y, Z and E acceleration in mm/s^2 for printing moves
          #define DEFAULT_RETRACT_ACCELERATION  3000    // E acceleration in mm/s^2 for retracts
          #define DEFAULT_TRAVEL_ACCELERATION   1000    // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves
          // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously)
          #define DEFAULT_XYJERK                20.0    // (mm/sec)
          #define DEFAULT_ZJERK                 0.4     // (mm/sec)
          #define DEFAULT_EJERK                 5.0    // (mm/sec)
