    After update to Release 1.22.1 the screen turned yellow
    PanelDue
    1001
    • Dep
      Dep last edited by
      I bought the panel a month or so ago. Today I turned it on, everything is ok. The screen is clear and the background is white. Updated to the latest firmware and the screen background turned yellow.
      What can be done and why did this happen?
      • Dep
        Dep last edited by
        PanelDue 7i.
        • Dep
          Dep last edited by
          On the screen i purchased on aliexpress there is a regulating resistor that allows you to adjust the white balance. How to adjust it on this screen?
          • sigxcpu
            sigxcpu last edited by
            https://forum.duet3d.com/topic/7739/paneldue-7i-screen-has-a-yellow-tint
              It looks like you have uploaded the firmware for the separate controller and screen, not the firmware for the integrated version.
              • Dep
                Dep last edited by
                I use PanelDue-v3-7.0-nologo.bin from here: https://github.com/dc42/PanelDueFirmware/releases
                What firmware should I use?
                  Use PanelDue-5.0i-7.0i.bin, or the -nologo version of that if you prefer.
                  Edit: I've just added a section about choosing the correct firmware binary to the release download page.
                  • Dep
                    Dep last edited by
                    Thanks!! Now working ok.
                    But there is a strange effect: when connecting a network cable, interference occurs. Now I will record a video.
                    • Dep
                      Dep last edited by
                      Watch the video please:
                      https://www.icloud.com/photos/#0-ndR61UDpYaNZ9omS6Sa2Gdg
                      (uploading now)
                      • Dep
                        Dep last edited by
                        Watch the video please - it is more convenient to watch here:
                        https://yadi.sk/i/nrCbFUQwjBtmHQ
                        I cleaned the board with gasoline - no change.
                        When connected via the SD connector, the noise disappears.
                        Tell me where to look for the SD connector scheme, since I do not need an SD connector, only a screen connection (4 wires).
                          Looks like you are using USB power only. My guess is that when you connect the network cable, the additional load is causing the 5V rail to sag, and this is causing the dot clock on the display to be unstable. If you apply VIN power to the Duet, it may work properly.
                          • Dep
                            Dep last edited by
                            Ahh! Thanks! I think so 🙂 Will try!
