    Duet 2 wifi Ambient temperature
    • Torro
      Torro last edited by
      Hi There,
      I'm planning an Upgrade from ramps and 12V to duet 2 and 24V.
      Do i get a Problem with the duet, when it has to work in temperatures about 30 to 40°C?
      A Fan 80*80mm only for the duet is planned.
      Thanks and Best regards, Flo
        40C is no problem at all for the Duet. You can use the built-in MCU temperature sensor to monitor the temperature, once you have calibrated it. You probably won't need the fan, but if you do then you can set it to run thermostatically when the MCU temperature is above a certain value.
        • Torro
          OK, thanks a lot!
