    Solved Auto Delta Calibration Odd Behavior
    1550
    • bricor
      bricor last edited by
      I installed an IR sensor and all appears to be working well except when performing more than 1 Auto Delta Calibration process in a row. The first pass works as it should.
      On the second pass when I press the Auto Delta Calibration button the printer homes and only probes the center of the bed. It reports back the standard message of # of probe points and deviation. If I home, the the carriages move off the switch and back on, noting else (normally the carriages move down 50mm).
      If I press the Auto Delta Calibration button again the carriages move off the switch and back on. The DWC reports in red windows 2 separate list of issues Error: Z probe was not triggered during probing move
      Error: Compensation or calibration cancelled due to probing errors
      G32
      I have to reset (emergency stop or power off) the printer to clear the issue.
      I updated from 2.02RC2 hoping it would help same exact behavior both firmware
      Firmware Version: 2.02RC4(RTOS) (2018-11-18b5)
      WiFi Server Version: 1.21
      Web Interface Version: 1.22.5
        Please post your bed.g file, also a M122 report taken after running auto calibration just once.
        What does auto calibration report the first time?
        • bricor
          bricor last edited by bricor
          Calibrated 7 factors using 7 points, deviation before 0.249 after 1.257
          ; bed.g
          ; called to perform automatic delta calibration via G32
          ; generated by RepRapFirmware Configuration Tool on Tue Sep 25 2018 16:48:33 GMT-0400 (Eastern Daylight Time)
          ;M98 Pdeployprobe.g ; deploy mechanical Z probe
          ; Probe the bed at 10 peripheral and 6 halfway points, and perform 7-factor auto compensation
          ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
          G28
          G30 P0 X0.00 Y100.00 Z-99999 H0
          G30 P1 X86.60 Y-50.00 Z-99999 H0
          G30 P2 X-86.60 Y-50.00 Z-99999 H0
          G30 P3 X0.00 Y50.00 Z-99999 H0
          G30 P4 X43.30 Y-25.00 Z-99999 H0
          G30 P5 X-43.30 Y-25.00 Z-99999 H0
          G30 P6 X0 Y0 Z-99999 S7
          ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
          ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
          ;M98 Pretractprobe.g ; retract mechanical Z probe
          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC4(RTOS) running on Duet WiFi 1.02 or later
          Board ID: 08DGM-917NK-F2MS4-7JTD0-3S86L-KYTWF
          Used output buffers: 3 of 20 (10 max)
          Static ram: 27476
          Dynamic ram: 98584 of which 0 recycled
          Exception stack ram used: 392
          Never used ram: 4620
          Tasks: NETWORK(ready,400) HEAT(blocked,1200) MAIN(running,620) IDLE(ready,200)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:12:14 ago, cause: power up
          Last software reset at 2018-11-24 02:38, reason: User, spinning module GCodes, available RAM 4668 bytes (slot 1)
          Error status: 0
          Free file entries: 10
          MCU temperature: min 22.5, current 32.9, max 33.2
          Supply voltage: min 12.9, current 13.2, max 13.6, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: standstill, SG min/max 0/596
          Driver 1: standstill, SG min/max 0/1023
          Driver 2: standstill, SG min/max 0/592
          Date/time: 2018-11-24 14:38:27
          Cache data hit count 2689145236
          Slowest loop: 6.85ms; fastest: 0.07ms
          I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
          Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 234, MaxWait: 274781ms, Underruns: 0, 0
          Scheduled moves: 106, completed moves: 106
          Bed compensation in use: none
          Bed probe heights: 0.581 0.212 -0.060 0.053 0.163
          Heater 0 is on, I-accum = 0.0
          Heater 1 is on, I-accum = 0.4
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 14.33ms; fastest: 0.00ms
          HTTP sessions: 2 of 8
          • WiFi -
            Network state is running
            WiFi firmware version 1.21
            WiFi MAC address 84:f3:eb:42:b3:24
            WiFi Vcc 3.44, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 16272
            WiFi IP address 192.168.1.16
            WiFi signal strength -64dBm, reconnections 0, sleep mode modem
            dc42 administrators @bricor last edited by
            @bricor said in Auto Delta Calibration Odd Behavior:
            I agree, that's very odd behaviour! Auto calibration is saying that it made matters worse.
            Please restart the Duet, connect a PC running Pronterface/YAT/etc. via USB, send M111 S1 P4 to enable Move debugging, then run auto calibration. Report the debug output from the PC here.
            • bricor
              I'll setup terminal and get back to you.
              I deleted config-overide rebooted and ran auto calibrate again
              This is the result
              Calibrated 7 factors using 7 points, deviation before 1.030 after nan
              One more tidbit, I was successful performing multiple Auto Calibrations using a BLTouch clone. I stopped using it since it had inconsistent results, (thats why I bought the DUET IR)
              I believe I was on 2.02RC2 but not sure.
                I have one other report of auto calibration producing 'nan' values. I believe these are generated when one or more probe points are not reachable using the current M665 parameters (even when one set of arms becomes horizontal), typically because the delta radius has been set incorrectly, or simply because when the bed.g file was generated, the probing radius was set too high (taking account of any XY offset of the Z probe). The debug data may confirm that.
                • bricor
                  When you said ". Report the debug output from the PC here" is that from terminal?
                  YAT is not displaying much.
                  Debugging enabled for modules: Move(4)<LF>Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15)<LF>ok<LF>RepRapFirmware for Duet 2 WiFi/Ethernet Version 2.02RC4(RTOS) dated 2018-11-18b5<LF><LF>Executing config.g...HTTP is enabled on port 80<LF>FTP is disabled<LF>TELNET is disabled<LF>Warning: Macro file config-override.g not found.<LF><LF>Done!<LF>RepRapFirmware for Duet 2 WiFi/Ethernet is up and running.<LF>WiFi module started<LF>WiFi module is conne
                  I've been successful with the Delta Parameters that I've been using for some time. They deviate only slightly from manual calibration.
                  I tried a new bed.g probing set using 80mm probing radius. same result.
                  The IR Board is positioned Y-21 (21mm In front of the nozzle, with z tower to the rear). (hopefully I have that correct)
                    When you run auto calibration, it should produced a lot more output.
                    • bricor
                      is there a parameter setting in YAT?
                      I've tried multiple times same result.
                      • bricor
                        I swapped IR boards (Since I don't know what else to try and I have a spare), same results.
                        I did manage to get the diag info using Pronterface
                        Connecting...
                        Printer is now online.
                        M111 S1 P4
                        SENDING:M111 S1 P4
                        Z probe offsets: -1.484 -0.935 -1.135 -0.586 -0.154 -0.354 0.486, mean -0.595, deviation from mean 0.612
                        Stops X0.000 Y0.000 Z0.000 height 316.200 diagonal 268.000 radius 138.000 xcorr 0.00 ycorr 0.00 zcorr 0.00 xtilt 0.000% ytilt 0.000%
                        Derivative matrix
                        0.0609 0.0609 0.8782 0.2582 0.0758 -0.0758 -1.0797
                        0.0686 0.7233 0.2080 0.4208 -0.0460 -0.1226 -1.1212
                        0.7234 0.0686 0.2080 0.4208 0.1226 0.0460 -1.1212
                        0.1587 0.1587 0.6825 0.4700 0.1002 -0.1002 -1.1347
                        0.1665 0.5013 0.3320 0.5574 -0.0318 -0.0898 -1.1556
                        0.5014 0.1665 0.3320 0.5575 0.0898 0.0318 -1.1556
                        0.2726 0.2726 0.4548 0.5849 0.0537 -0.0536 -1.1627
                        Normal matrix
                        0.9104 0.3694 0.6723 0.9555 0.1605 -0.0093 -2.2227 1.1394
                        0.3694 0.9102 0.6722 0.9553 0.0093 -0.1604 -2.2224 0.9413
                        0.6723 0.6722 1.7508 1.3588 0.1946 -0.1946 -3.4851 2.0816
                        0.9555 0.9553 1.3588 1.6054 0.1627 -0.1626 -3.7242 1.5288
                        0.1605 0.0093 0.1946 0.1627 0.0449 -0.0017 -0.4110 0.2683
                        -0.0093 -0.1604 -0.1946 -0.1626 -0.0017 0.0449 0.4108 -0.2102
                        -2.2227 -2.2224 -3.4851 -3.7242 -0.4110 0.4108 8.9900 -4.6103
                        Solved matrix
                        -2.2227 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 3316.2751
                        0.0000 -0.5408 0.0000 0.0000 0.0000 0.0000 0.0000 806.0934
                        0.0000 0.0000 0.6967 0.0000 0.0000 0.0000 0.0000 -1038.0209
                        0.0000 0.0000 0.0000 0.0510 0.0000 0.0000 0.0000 -19.4663
                        0.0000 0.0000 0.0000 0.0000 0.0019 0.0000 0.0000 -0.0262
                        0.0000 0.0000 0.0000 0.0000 0.0000 0.0015 0.0000 0.0314
                        0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 -0.0001
                        Solution: -1491.9964 -1490.4760 -1489.9205 -381.8478 -13.8789 21.5039 -1475.2585
                        Residuals: 0.0000 0.0000 0.0000 -0.0000 -0.0000 -0.0000 0.0000
                        Expected probe error: -2425.4219 -2439.0444 -2440.5215 -2440.8616 -2443.4946 -2443.7583 -2444.4780
                        Derivative matrix
                        -0.1685 -0.2423 1.4087 0.2783 -0.2399 0.3497 0.9692
                        0.1227 0.9259 -0.0500 -0.0684 -0.0488 0.0836 1.0065
                        0.8765 0.1062 0.0171 -0.0848 -0.0232 0.0336 1.0089
                        0.0531 0.0055 0.9418 -0.0299 0.0421 -0.0043 1.0028
                        0.2051 0.5981 0.1959 -0.1746 -0.0110 -0.0555 1.0175
                        0.5792 0.1904 0.2301 -0.1782 0.0708 0.0018 1.0175
                        0.2802 0.2667 0.4523 -0.1825 0.0793 -0.0757 1.0187
                        Normal matrix
                        1.2705 0.5555 0.1217 -0.3214 0.0773 -0.0510 1.9811 4760.7002
                        0.5555 1.3925 -0.0991 -0.3269 0.0388 -0.0568 1.8837 4522.1376
                        0.1217 -0.0991 3.1700 0.2081 -0.2462 0.4403 3.1708 7781.6607
                        -0.3214 -0.3269 0.2081 0.1858 -0.0879 0.1121 -0.4595 -1079.9139
                        0.0773 0.0388 -0.2462 -0.0879 0.0737 -0.0942 -0.1211 -314.5505
                        -0.0510 -0.0568 0.4403 0.1121 -0.0942 0.1393 0.3210 807.4441
                        1.9811 1.8837 3.1708 -0.4595 -0.1211 0.3210 7.0841 17178.3176
                        Solved matrix
                        1.9811 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 2443.6416
                        0.0000 0.8643 0.0000 0.0000 0.0000 0.0000 0.0000 1067.7703
                        0.0000 0.0000 2.7297 0.0000 0.0000 0.0000 0.0000 3374.5799
                        0.0000 0.0000 0.0000 0.0632 0.0000 0.0000 0.0000 5.3086
                        0.0000 0.0000 0.0000 0.0000 0.0047 0.0000 0.0000 0.0108
                        0.0000 0.0000 0.0000 0.0000 0.0000 -0.0074 0.0000 -0.0401
                        0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 -0.0000 -0.0013
                        Solution: 1233.4769 1235.3774 1236.2498 83.9775 2.3079 5.3981 1203.3699
                        Residuals: 2423.9380 2438.1091 2439.3862 2440.2751 2443.3408 2443.4045 2444.9639
                        Expected probe error: nan nan nan nan nan nan nan
                        Stops X-2.756 Y0.664 Z2.092 height nan diagonal -3.889 radius -159.870 xcorr -11.57 ycorr 26.90 zcorr 0.00 xtilt 0.000% ytilt 0.000%
                        Disconnected.
                        • bricor
                          I looked through the diag data and I don't know what I'm looking for and I really can't make sense of any of it.
                          I've tried all that I can, I keep getting erratic results. Really far out numbers.
                          Before:
                          Diagonal 268.000, delta radius 138.000, homed height 316.200, bed radius 110.0, X 0.000°, Y 0.000°, Z 0.000°
                          Calibrated 7 factors using 7 points, deviation before 0.833 after 0.880
                          After:
                          Diagonal 621.396, delta radius 205.951, homed height 316.909, bed radius 110.0, X 5.334°, Y -1.442°, Z 0.000°
                          I'm going to manually calibrate so I can get it back in service.
                            Ah I see the problem. YAT isn't recognising LF as the line ending character, so it's putting everything on one line, and truncating it. In YAT, go to Terminal/Settings/Text Settings and change the EOL sequence to <LF>.
                            • bricor
                              The data looks to be about the same as I posted from Pronterface. You might have missed my posts after the YAT question.
                              M111 S1 P4<CR>
                              ok
                              Z probe offsets: 0.591 1.065 -0.610 1.376 1.659 0.696 2.048, mean 0.975, deviation from mean 0.804
                              Derivative matrix
                              Normal matrix
                              0.9104 0.3694 0.6723 0.9555 0.1605 -0.0093 -2.2227 -1.0699
                              0.3694 0.9102 0.6722 0.9553 0.0093 -0.1604 -2.2224 -2.4886
                              0.6723 0.6722 1.7508 1.3588 0.1946 -0.1946 -3.4851 -3.2662
                              0.9555 0.9553 1.3588 1.6054 0.1627 -0.1626 -3.7242 -3.5016
                              0.1605 0.0093 0.1946 0.1627 0.0449 -0.0017 -0.4110 -0.1787
                              -0.0093 -0.1604 -0.1946 -0.1626 -0.0017 0.0449 0.4108 0.5781
                              -2.2227 -2.2224 -3.4851 -3.7242 -0.4110 0.4108 8.9900 7.8125
                              Solved matrix
                              -2.2227 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 2889.3218
                              0.0000 -0.5408 0.0000 0.0000 0.0000 0.0000 0.0000 703.4698
                              0.0000 0.0000 0.6967 0.0000 0.0000 0.0000 0.0000 -905.9999
                              0.0000 0.0000 0.0000 0.0510 0.0000 0.0000 0.0000 -17.0178
                              0.0000 0.0000 0.0000 0.0000 0.0019 0.0000 0.0000 -0.0241
                              0.0000 0.0000 0.0000 0.0000 0.0000 0.0015 0.0000 0.0292
                              Solution: -1299.9096 -1300.7239 -1300.4244 -333.8168 -12.7325 19.9704 -1285.9941
                              Expected probe error: -2035.5796 -2058.8149 -2060.0117 -2059.7983 -2066.9802 -2067.0186 -2068.2925
                              Derivative matrix
                              -0.2682 -0.3717 1.6391 0.5011 -0.3729 0.5194 0.9479
                              0.0476 1.0614 -0.1086 0.0183 -0.0201 0.0952 0.9979
                              1.0260 0.0049 -0.0323 0.0134 -0.0232 0.0018 0.9985
                              -0.0183 -0.0989 1.1163 0.0616 -0.0140 0.0763 0.9943
                              0.1587 0.6494 0.1935 -0.1501 -0.0122 -0.0500 1.0150
                              0.6519 0.1141 0.2325 -0.1453 0.0732 0.0055 1.0144
                              0.2643 0.2197 0.5164 -0.1654 0.0696 -0.0562 1.0162
                              Normal matrix
                              1.6472 0.3926 -0.1797 -0.2831 0.1397 -0.1535 1.8904 3849.8519
                              0.3926 1.7576 -0.5695 -0.3233 0.1342 -0.1438 1.6117 3267.6931
                              -0.1797 -0.5695 4.3038 0.7395 -0.5734 0.8887 3.4799 7294.1970
                              -0.2831 -0.3233 0.7395 0.3264 -0.2087 0.2828 0.1001 259.6438
                              0.1397 0.1342 -0.5734 -0.2087 0.1506 -0.1996 -0.2781 -607.2070
                              -0.1535 -0.1438 0.8887 0.2828 -0.1996 0.2904 0.5627 1206.0157
                              1.8904 1.6117 3.4799 0.1001 -0.2781 0.5627 6.9720 14385.6735
                              Solved matrix
                              1.8904 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 1050.4940
                              0.0000 1.4229 0.0000 0.0000 0.0000 0.0000 0.0000 788.1418
                              0.0000 0.0000 4.2567 0.0000 0.0000 0.0000 0.0000 2365.7897
                              0.0000 0.0000 0.0000 0.1409 0.0000 0.0000 0.0000 15.9871
                              0.0000 0.0000 0.0000 0.0000 0.0099 0.0000 0.0000 0.1313
                              0.0000 0.0000 0.0000 0.0000 0.0000 0.0095 0.0000 0.0006
                              Solution: 555.6917 553.9042 555.7788 113.4557 13.2953 0.0585 1506.1367
                              Residuals: 2036.1707 2059.8796 2059.4016 2061.1743 2068.6389 2067.7148 2070.3408
                              Expected probe error: -898.2925 -955.3685 -954.5236 -952.5867 -987.6226 -982.6718 -989.0720
                              Stops X1.010 Y-1.592 Z0.582 height -680.433 diagonal 488.143 radius -82.361 xcorr 0.56 ycorr 20.03 zcorr 0.00 xtilt 0.000% ytilt 0.000%
                                The matrix is numerically unstable (the diagonal element of the last row of the solved matrix is showing as zero). Try 6-factor calibration instead of 7. That's S6 on the final G30 command in bed.g instead of S7.
                                • bricor
                                  6 Factor seems to have made it work
                                  I ran the calibration and it was finally successful running multiple passes. The printer is cold and in need of a full calibration (i gave up last night/early am in the middle of manual calibration) but the results are good.
                                  3 passes in a row
                                  :17:39 PMM665
                                  Diagonal 268.000, delta radius 133.271, homed height 314.718, bed radius 110.0, X 1.334°, Y 0.015°, Z 0.000°
                                  12:17:35 PMG32
                                  Calibrated 6 factors using 7 points, deviation before 0.041 after 0.017
                                  12:16:32 PMG32
                                  Calibrated 6 factors using 7 points, deviation before 0.155 after 0.034
                                  12:15:38 PMM665
                                  Diagonal 268.000, delta radius 132.043, homed height 314.423, bed radius 110.0, X 1.683°, Y -1.559°, Z 0.000°
                                  12:15:32 PMG32
                                  Calibrated 6 factors using 7 points, deviation before 1.261 after 0.139
                                  12:14:35 PMM665
                                  4th & 5th pass 10 Point -
                                  12:46:03 PMM665
                                  Diagonal 268.000, delta radius 132.788, homed height 314.692, bed radius 110.0, X 1.361°, Y 0.113°, Z 0.000°
                                  12:43:50 PMG28
                                  12:36:22 PMG32
                                  Calibrated 6 factors using 10 points, deviation before 0.121 after 0.038
                                  12:35:10 PMM665
                                  Diagonal 268.000, delta radius 132.290, homed height 314.515, bed radius 110.0, X 1.037°, Y -0.048°, Z 0.000°
                                  12:35:04 PMG32
                                  Calibrated 6 factors using 10 points, deviation before 1.096 after 0.126
                                  YAT diag data (pass 5)
                                  M111 S1 P4
                                  ok
                                  Z probe offsets: -0.087 0.009 0.012 0.002 -0.049 0.050 0.085, mean 0.003, deviation from mean 0.053
                                  Stops X1.561 Y-0.472 Z-1.089 height 314.718 diagonal 268.000 radius 133.271 xcorr 1.33 ycorr 0.01 zcorr 0.00 xtilt 0.000% ytilt 0.000%
                                  Derivative matrix
                                  0.0555 0.0552 0.8892 0.2258 0.0645 -0.0645
                                  0.0632 0.7298 0.2071 0.3908 -0.0406 -0.1187
                                  0.7304 0.0556 0.2141 0.3907 0.1297 0.0351
                                  0.1548 0.1533 0.6919 0.4407 0.0917 -0.0917
                                  0.1632 0.5023 0.3346 0.5294 -0.0308 -0.0862
                                  0.5045 0.1570 0.3385 0.5294 0.0899 0.0284
                                  0.2711 0.2677 0.4612 0.5571 0.0502 -0.0502
                                  Normal matrix
                                  0.9191 0.3473 0.6764 0.8954 0.1639 -0.0130 -0.0452
                                  0.3473 0.9109 0.6629 0.8851 0.0073 -0.1546 -0.0088
                                  0.6764 0.6629 1.7974 1.2836 0.1835 -0.1802 0.0316
                                  0.8954 0.8851 1.2836 1.4215 0.1491 -0.1462 -0.0377
                                  0.1639 0.0073 0.1835 0.1491 0.0426 -0.0005 -0.0061
                                  -0.0130 -0.1546 -0.1802 -0.1462 -0.0005 0.0386 -0.0061
                                  Solved matrix
                                  0.9191 0.0000 0.0000 0.0000 0.0000 0.0000 0.4568
                                  0.0000 0.7797 0.0000 0.0000 0.0000 0.0000 -0.1543
                                  0.0000 0.0000 1.0869 0.0000 0.0000 0.0000 0.2634
                                  0.0000 0.0000 0.0000 0.0600 0.0000 0.0000 -0.0196
                                  0.0000 0.0000 0.0000 0.0000 0.0018 0.0000 -0.0036
                                  0.0000 0.0000 0.0000 0.0000 0.0000 0.0014 -0.0013
                                  Solution: 0.4969 -0.1979 0.2423 -0.3264 -1.9328 -0.9136
                                  Residuals: 0.0055 0.0053 0.0053 -0.0209 -0.0205 -0.0205 0.0458
                                  Expected probe error: 0.0164 0.0035 0.0127 -0.0181 -0.0233 -0.0197 0.0442
                                  Derivative matrix
                                  0.0471 0.0601 0.8929 0.2177 0.0554 -0.0708
                                  0.0635 0.7277 0.2088 0.3941 -0.0392 -0.1179
                                  0.7340 0.0611 0.2049 0.3846 0.1203 0.0392
                                  0.1485 0.1576 0.6939 0.4360 0.0894 -0.0950
                                  0.1623 0.5028 0.3349 0.5293 -0.0283 -0.0860
                                  0.5054 0.1617 0.3329 0.5259 0.0880 0.0300
                                  0.2688 0.2711 0.4601 0.5548 0.0515 -0.0508
                                  Normal matrix
                                  0.9211 0.3535 0.6551 0.8832 0.1554 -0.0086 -0.0058
                                  0.3535 0.9142 0.6744 0.8937 0.0103 -0.1547 0.0015
                                  0.6551 0.6744 1.7991 1.2656 0.1715 -0.1879 -0.0113
                                  0.8832 0.8937 1.2656 1.4053 0.1417 -0.1461 -0.0038
                                  0.1554 0.0103 0.1715 0.1417 0.0383 -0.0006 -0.0019
                                  -0.0086 -0.1547 -0.1879 -0.1461 -0.0006 0.0403 0.0002
                                  Solved matrix
                                  0.9211 0.0000 0.0000 0.0000 0.0000 0.0000 -0.0229
                                  0.0000 0.7785 0.0000 0.0000 0.0000 0.0000 -0.0037
                                  0.0000 0.0000 1.1034 0.0000 0.0000 0.0000 -0.0206
                                  0.0000 0.0000 0.0000 0.0608 0.0000 0.0000 0.0019
                                  0.0000 0.0000 0.0000 0.0000 0.0000 0.0014 0.0000
                                  Solution: -0.0248 -0.0047 -0.0187 0.0318 0.0189 0.0100
                                  Residuals: -0.0980 0.0104 0.0043 -0.0005 -0.0458 0.0496 0.0870
                                  Expected probe error: 0.0055 0.0052 0.0053 -0.0209 -0.0205 -0.0205 0.0458
                                  Stops X1.869 Y-0.839 Z-1.029 height 314.714 diagonal 268.000 radius 132.977 xcorr -0.58 ycorr -0.89 zcorr 0.00 xtilt 0.000% ytilt 0.000%
                                    That's looking much better!
                                    • bricor
                                      Is the answer to the issue, don't use 7 factor?
                                        Yes, we don't recommend 7-factor calibration unless you can probe a lot of points including some that are between two towers and outside the normal print radius.
                                        • bricor
                                          Thank you for your help once again. Issue solved.
