    Filament Runout switch on Duet 0.6
    1389
    • DeltaCon
      DeltaCon last edited by
      I have a Delta printer with a Duet 0.6 board. Last week I miscalculated a job and ran out of filament after a 15hrs printjob. That reminded me that I once bought a microswitch with enclosure, to be used as a runout detection. I never took the time to implement that, but now it seems to be worth an effort 😉
      I read on these forums that usually such a switch gets connected to the E0 endstop. Problem is that I have that in use for the FSR system. Is there an other way to get this connected? It seems that I have used most standard connections to this board. I would gladly buy a new Duet board, but I am clipping all spendings on this machine to put money aside for a new build (probably RailCore)
      If you think trial and error is dangerous, try routine. That's even more so!
        See https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_filament-out_sensors.
        • DeltaCon
          Yes DC, I have seen that page, but there is no info about connecting to a 0.6 version Duet other than "connect the switch to an unused endstop connector". The duet 0.6 does not have a free endstop connector, if there is a z-probe connected to E0 already. Hence my question whether there is an alternative connection possible on a Duet 0.6 board, probably through the expansion connector or something?
            dc42 administrators @DeltaCon last edited by
            The Duet 06 has 4 additional endstop inputs on the expansion connector. I suggest you look at the DueX4 schematic to work out which pins they are. Alternatively, most types of Z probe can now be connected to the Z probe connector, so you could free up your E0 endstop input.
            DeltaCon 1 Reply Last reply Reply Quote 0
            • DeltaCon
              DeltaCon @dc42 last edited by
              @dc42, Thanks! If I understand correctly I could connect the filament run-out microsowitch directly to the pins of the expansion-header for the duex4? Hmm, that's interesting! Let's say I would use the endstop E4 for this purpose, I would need to use pins 2 - GND and 50 - PC19 - E4_STOP, correct?
              And then put a line in the config.g:
              M591 D4 P1 ; or P2 depending on microswitch behaviour
              Thanks, I'll try that, I am glad that I can put the filamentswith to use afterall. I am SO willing to buy a new duet, but if so, I will do that for a new build, not for the current RMax 😉
                You may also need to connect a pullup resistor between that endstop connection on the expansion connector and the +3.3V pin.
                DeltaCon 2 Replies Last reply Reply Quote 0
                • DeltaCon
                  @dc42, Is it harmless to try without? What could be the effects if I leave that out? I am probably not electronics-savy enough to figure that out...
                    It's harmless to try without. The risk is that it might sense the switch as closed when it is open.
                    • DeltaCon
                      DeltaCon last edited by DeltaCon
                      Thanks DC.
                      I am sorry to keep pushing questions... I have the switch attached and was wondering how to check the status of this switch. I would think M119 would report that (like the XYZ endstops and the Z-probe status) but it doensn't. Also I see some posts mentioning a status in DWC but I don't see any position where to find that (presumably at the sensor grid in the upper right of DWC window).
                      Whether filament is in or out the switch DWC is telling me the filament is out immediatly when T1 wants to start heating.
                      I have put:
                      M591 D0 P2 C7 S1
                      in the config.g
                      As I understand it C7 stands for Endstop E4, and that is pin50 on the expansion slot.
                      I have the other side of the switch connected to GND Pin 2
                      When connected to to +3.3V Pin 3 nothing happens at all so I guess I should connect it to ground indeed, but I am uncertain.
                      I checked the switch, and it works normally. I get 0 Ohms when I pull the filament out, so I guess I should use P2 indeed.
                      So, what am I doing wrong?
                      • DeltaCon
                        @dc42 said in Filament Runout switch on Duet 0.6:
                        I read somewhere that for most 3.3V applications a 10K resistor will do. Should I simply use something like this?
                        https://www.conrad.nl/p/koolfilmweerstand-10-k-axiaal-bedraad-0207-025-w-5-yageo-cfr-25jt-52-10k-1-stuks-1417697
                          @deltacon said in Filament Runout switch on Duet 0.6:
                          Yes.
                          • DeltaCon
                            I am not getting it to work... Does the switch go between Endstop pin and GND or between Endstop pin and +3.3V?
                            I have put a resistor 10K Ohm between Endstop pin and +3.3V like David suggested.
                            M591 D0 P1 C7 S1 is in my config.g, C7 since I am connecting to extruder endstop 4
                            If I connect to GND the Duet becomes unresponsive until disconnection.
                            If I connect it to +3.3V nothing happens
                            With switch on +3.3V I measure
                            • With filament present 0.001V and 8.7K Ohm
                            • With filament absent 0.000V and 0.0K Ohm
                              The +3.3V pin gives 3.3V correctly, measured against GND
                            I also tried the external trigger M581 E7 T1 S0 C1 command (tried E4 also, because I was unsure if there also the axes endstops are counted). But no change whatsoever.
                            Any ideas?
                              Are you sure that you have connected it to the correct endstop input pin on the expansion connector? With the resistor connected between that pin and +3.3V, the voltage on the pin relative to ground should be 0V when the switch is closed and almost 3.3V when the switch is open.
                              • DeltaCon
                                DeltaCon @dc42 last edited by DeltaCon
                                @dc42 Yes I think so. I wanted to use the endstop pin for E4:
                                And on thye board that is the far left pin closest to the edge of the board:
                                Do I need to "activate this endstop by a "M574 E4 S1" command in config.g?
                                • DeltaCon
                                  Okay, I had a little success!
                                  I rewired today because I wanted to remeasure David's suggestion above. And now it seems to work as intended! Excellent! No Idea what I did wrong the first try. Thanks David for your assistence!
                                  • DeltaCon
                                    I am running this filament runout setup in test mode now. It is functional, but the filament is not running through the switch for now. Pulling a small piece of filament out of the switch makes a pause happening just fine. However during normal prints, with a piece of filament present in the switch, it happens every now and then that a false positive (negative?) is triggered. I am confident that it is not the switch itself causing the problem. What else can make a trigger happen? EMI? Is the pullup resistor 10K Ohms no. Should I increase or lower the resistor?
                                      If it's a normal 3-terminal microswitch then I suggest you use the 2 contacts that are closed when filament is present and open when it is not. That will make the wiring less sensitive to noise pickup than the other way round.
                                      • DeltaCon
                                        Yeah, that makes sense even for an electronics noob like me 😉
                                        I changed that, and will report back. Thanks!
