Pause and store print state on network signal (UPS)
I have a UPS connected to synology NAS and the printer. The NAS monitors the NAS and sends a signal when on battery and 10% left of said battery (this is 10 minutes or so).
Can I configure the duetwifi to listen to this signal and do a safe shutdown and store current print progress so I can resume printing when power is back up?
I know the duet has such a system in place if it detects the power going down. However can I also trigger it on a network event?
Currently you can't trigger it directly on a network event, but you can trigger a pause/save on a change of state of a spare endstop input.
Thnx. That might be usable. I have some arduinos and other things lying around!
If I come up with a solution. I'll post it here so others may reuse it.
PS would be a nice and fairly easy to implement feature. If I remember correctly duetwifi firmware is open source if I find the time I might do a pull and see if I can add it.
If you have a Wifi/ethernet device (Arduino/ESP8266/ESP32) you can use a Telnet connection to send a gcode to pause the print.
Maybe you can even run this on your NAS (some of them can run custom scripts or programs).
That's a great idea actually! I have a Synology, so creating something to do this wouldn't be a problem.
Would a Pause command be sufficient to make a resume after power restore possible?
@nemesis said in Pause and store print state on network signal (UPS):
Yes. A restore point is created any time a pause is triggered.
Thank you for the confirmation Phaedrux. I'll do some testing this week.
@phaedrux said in Pause and store print state on network signal (UPS):
Bear in mind that if you cancel the print while it is paused, the restore point will be deleted. So turn the printer off without cancelling the print.
@dc42 I didn't realize that. Good to know.
