    Fan Port 0 damaged. Any chance to repair?
    • Peter_O
      Peter_O last edited by
      I seem to have damaged PWM fan port 0 by short cutting it (small spark 😉 ).
      After that a voltmeters shows 9V instead of 12V when setting port to 255, but the fan is not running at all.
      Fortunately all other ports work fine. So I remapped the parts cooling fan to port 2 and the printer is running again.
      Question: Is there any possibility to repair pwm port 0?
        https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Fan_mosfet
        Peter_O 1 Reply Last reply Reply Quote 0
        • Peter_O
          Peter_O @dc42 last edited by
          That was fast! Perfect! Thanks a lot!
          I might not be the first one ... 🙂
            dc42 administrators @Peter_O last edited by
            @peter_o said in Fan Port 0 damaged. Any chance to repair?:
            You are certainly not the first one! Damaged fan mosfets cause by fan shorts are the most common way for users to damage a Duet. The 1A fuse we added in later revisions protects the PCB from damage, but the fuse isn't quick enough to protect the mosfets.
