    Unable to Connect to Duet Console from my laptop
    • rikesh942018
      rikesh942018 last edited by
      So I have a weird problem, I got a spare laptop for running my printers but for some reason I am unable to connect to the Duet with this laptop.
      I am able to connect to the machine using all other devices I have except this laptop, so I am highly assuming its something to do with the laptop I have.
      The machine is running in access point mode, as it will be going to a location without a router.
      Has anyone had a similar problem, the laptop is Windows 10
      • Danal
        Danal last edited by
        Need more detail...
        When/where does failure occur. For example, does Laptop even join the AP network?
        • rikesh942018
          It is able to access the UI for few seconds and then it loses connection, and I am not able to access it again until I do a complete restart
          • timcurtis67
            timcurtis67 last edited by
            Are you using Chrome or Explorer? I would try to connect with Chrome.
            • rikesh942018
              Have tried chrome and explorer, same problem.
                It might be an MSS problem. Can you run Wireshark on the laptop, to get a trace of the session?
                • rikesh942018
                  Thanks for the input guys, I have no idea what I changed but reinstalling the firmware on the duet and reinstalling Chrome OS on the old laptop has seemed to fix the issue and I now do not have any problems.
