    connect 2 AC heated bed keenovo 220 v/750 w
    • yamanundefined
      yaman
      Hi all
      I Have duet wifi and I have 2 heat bed 300X300 keenovo 220 v/750 w connected with ssr dc/Ac 10A
      also I have PT100 Daughter Board and Thermocouple Daughter Board
      I connect the bed heated bed out put to dc/ac ssr and the keenovo take power from ssr heated bed
      my question is how to sent signal to the second heat bed via ssr
      because it has only 1 output for heated bed
      I read that I can connect 2 temperature sensors in Parallel and sent 1 signal to ssr so they work on and off together but is possible to run split ?
      can I use 5 vdc out put signal that build in duet WiFi upper the input?
      if yes how to setup that ?
        You can run them split if you connect the second SSR and thermistor to a spare heater and thermistor channel. If you are not using the E1 heater/thermistor connections, you can use those. Use the M140 command to configure multiple bed heaters.
        yamanundefined 2 Replies Last reply Reply Quote 0
        • yamanundefined
          yaman @dc42
          my machine multi color 😓 😓 😓 😓
          • yamanundefined
            yaman @dc42
            also I use
            Duet Expansion Breakout Board
              dc42 administrators @yaman
              @yaman said in connect 2 AC heated bed keenovo 220 v/750 w:
              also I use
              In that case you can connect the SSR control input terminals to of the servo outputs on the breakout board, between the PWM pin (+) and the Ground pin (-).
              • yamanundefined
                yaman
                thanks i will try that
