    Solved G-Code from within Macro apparently not executed
    • t0bias
      t0bias last edited by
      I have a Raspberry Pi with a Pi-Camera in place to provide the Webcam-Stream for the WebControl User Interface.
      The Pi is configured to listen on one of its GPIO-Pins for a rising Edge in order to properly Shutdown before I cut the power. I connected that Pin to the Pin 63 on my Duet WiFi (no Thermocouple in place) and created a Macro with just the following 3 lines:
      M42 P63 S255
      G4 500
      M42 P63 S0
      to keep the Line High for half a Second just to be sure.
      Now upon running the Macro, nothing seems to happen. When I do enter the first Command (M42 P63 S255) in the WebControl "Send Gcode" Field in the Navigation-Bar, everything works flawlessly and the Pi shuts down immediately as it is supposed to.
      Are there certain commands that cannot be used within Macros or did I miss something else here?
      Thanks!
      JoergS5 1 Reply Last reply Reply Quote 0
      • JoergS5
        JoergS5 @t0bias last edited by JoergS5
        @t0bias I would try G4 P500, meaning wait 500 ms, according to https://reprap.org/wiki/G-code#G4:_Dwell you need to use P for ms or S for seconds.
        • t0bias
          Thanks so much, that totally did it! Didn't see that myself.. 🙄
