    M226 Pause Gcode ignored
    2380
    • totalitarian
      totalitarian last edited by
      I have a corexy printer running a duet wifi. When I run directly via the duet controller, this part of my gcode will pause the printer after auto levelling.
      G28 ; home all axes
      G29; Auto Level
      M226 ; pause
      G1 X40 Y10 F6000; move to prime position
      Now, as I also run a Mosaic Pallet, in order to get digital pinging working, I stream gcode to the duet via octprint. The issue i'm facing is that the M226 pause is completely ignore. Any idea why that would be?
      OctoPrint 1.3.9 running on OctoPi 0.15.1 / Duet 2.02RC3(RTOS) (2018-10-17b2)
        https://duet3d.dozuki.com/Wiki/GCode#Section_M226_Gcode_Initiated_Pause
        M226: Gcode Initiated Pause
        Example
        M226
        Initiates a pause in the same way as if the pause button is pressed. That is, program execution is stopped and the printer waits for user interaction. M226 is intended for use in the GCode file being printed, for example to pause after a particular layer has completed. So it waits until all the moves in the queue have been completed. M25 is intended for use from a different source of GCodes (Like the web interface console, PanelDue or a Macro) so if you need to pause from those use M25 instead.
        I think the issue is that the M226 is being sent over USB rather than being run from an onboard gcode file on the SD card. Try M25 instead?
        https://duet3d.dozuki.com/Wiki/GCode#Section_M25_Pause_SD_print
        M25: Pause SD print ¶
        Example
        M25
        The machine pauses printing at the current position within the file. To resume printing, use M24. Do not use this code to pause the print in the currently printing G-code file, use M226 instead. M226 is intended for use in the GCode file being printed, for example to pause after a particular layer has completed. So it waits until all the moves in the queue have been completed. M25 is intended for use from a different source of GCodes (like the web interface console, PanelDue or Macro)
        Prior to pausing, the macro file pause.g is run. This allows the head to be moved away from the print, filament to be retracted, etc.
        • totalitarian
          I think you are right. It worries me it says not to use M25 code to pause the print in the currently printing G-code file though
            Yeah I'm not sure what the real intention is there.
            You might be able to find some more context by searching the forum for M226 and M25. I know it's been discussed a few times. @dc42 would have to answer on the best way to implement a pause for the Mosaic Palette. Perhaps better support could be implemented if what's available doesn't already fit the need.
              dc42 administrators @totalitarian last edited by dc42
              @totalitarian said in M226 Pause Gcode ignored:
              M25 is an asynchronous pause (i.e. pause as soon as possible). It used not to work inside the GCode file being printed, but I fixed that about 2 years ago. So it should be OK now.
              Whereas M226 is a synchronous pause (i.e. wait until all preceding moves have been completed, then pause), and only works when used within the GCode file being printed.
              • totalitarian
                Thanks, M25 indeed pauses. How to resume the print from DWC though?
                  Pressing the Resume button should work, just as for any other type of pause. Doesn't it?
                  totalitarian 1 Reply Last reply Reply Quote 0
                  • totalitarian
                    totalitarian @dc42 last edited by
                    @dc42 The resume button doesn't appear when the command is sent via usb
                      Like I said, M226 on!y works from within a file being printed from within the SD card.
                        You could create a macro to send M24 to resume.
                        https://duet3d.dozuki.com/Wiki/GCode#Section_M24_Start_resume_SD_print
                          I've decided to allow M226 (and M600) even when no SD card print is in progress. This will allow it to be used in GCode files streamed over USB as well as within SD card print files. I'll implement this in 2.02RC6.
                          JRDM totalitarian 2 Replies Last reply Reply Quote 0
                          • JRDM
                            JRDM @dc42 last edited by
                            @dc42 Does that mean this will now work on a macro too? I found that M25 and M226 both get ignored in macros at least when run within DWC.
                            • totalitarian
                              @dc42 You sir are a true gentleman. Thanks
                                dc42 administrators @JRDM last edited by
                                @jrdm said in M226 Pause Gcode ignored:
                                M25 should already work from within a macro. Please try it again.
                                JRDM 1 Reply Last reply Reply Quote 0
                                • PlasticMetal
                                  PlasticMetal last edited by
                                  I've recently run into an intermittent problem, where hitting 'resume' from the DWC after an M226 (manually inserted in gcode file) will sometimes drop the Duet Ethernet (v1.03) from the network. This is similar to what others have described, other than it isn't guaranteed to fail. Unfortunately, when it does, the build is ruined. Yesterday, resume worked once and failed twice. I'm running 2.01.
                                  My pause & resume macros are pretty much stock from the configuration tool.
                                  Pause.g:
                                  M83
                                  G1 E-3 F3600
                                  G91
                                  G1 Z10 F5000
                                  G90
                                  G1 X0 Y130 F6000
                                  Resume.g:
                                  G1 R1 Z5 F6000
                                  G1 R1
                                  M83
                                  G1 E2.5 F3600
                                  Thanks for any suggestions!
                                    dc42 administrators @PlasticMetal last edited by
                                    @plasticmetal said in M226 Pause Gcode ignored:
                                    Pause.g:
                                    M83
                                    G1 E-3 F3600
                                    G91
                                    G1 Z10 F5000
                                    G90
                                    G1 X0 Y130 F6000
                                    Resume.g:
                                    G1 R1 Z5 F6000
                                    G1 R1
                                    M83
                                    G1 E2.5 F3600
                                    Please try the just-released 2.02RC6 release (carefully - and read the upgrade notes) because this may have been be fixed already.
                                    • PlasticMetal
                                      Thanks, David. It worked three times yesterday with the new release, so hopefully it's good to go.
                                      Now to just find a quality heater cartridge...
                                      • JRDM
                                        OK I tried again. I did the full update to RC6 yesterday and this still happens:
                                        Error: M25: Cannot pause print, because no file is being printed!
                                        I'm calling the macro by clicking the button in DWC
                                          Calling which macro?
                                          • JRDM
                                            JRDM @dc42 last edited by JRDM
                                            @dc42 it's in a macro I wrote that's in my DuetM's standard macro folder.
                                              You mean you have M25 in a macro, and you are invoking that macro from DWC or PanelDue? I've just tested that, and it works for me.
                                              • JRDM
                                                @dc42 Yes. To test it in isolation, I just now put M25 in its own macro to test it by itself. I invoked it by clicking it from the DWC Machine Control panel, the User-Defined Macro list and I still get:
                                                M98 P"0:/macros/Pause"
                                                My board and firmware versions:
                                                Firmware Name: RepRapFirmware for Duet 2 Maestro
                                                Firmware Electronics: Duet Maestro 1.0
                                                Firmware Version: 2.02RC6(RTOS) (2018-12-15b2)
                                                Web Interface Version: 1.22.5
                                                  Were you definitely printing from the SD card on the Duet at the time?
