    M564 ignored, problem with homing
    • taconite
      taconite last edited by
      Hello Guys,
      I have a custom delta style printer.
      I have a problem with my fresh Duet Wifi (rev. 1.03).
      Everything is wired. Endstops work properly (and are shown on the correct axis in the duet web page).
      When I try to move the stepper motors after I punshed in the M564 command (as suggested in the manual (https://duet3d.dozuki.com/Guide/3.)+Configuration+(General+Cartesian)/10 ). I get this error message:
      M120
      G91
      G1 X1 F6000
      M121
      Error: G0/G1: insufficient axis homed
      when I try to home the axis. only one tower is moving (at x homing, y homing and z homing (manually)). the other stepper motors are humming/buzzing.
      homedelta.g
      ; homedelta.g
      ; generated by RepRapFirmware Configuration Tool on Sun Oct 28 2018 20:49:00 GMT+0100
      G91 ; relative positioning
      G1 S1 X945 Y945 Z945 F1800 ; move all towers to the high end stopping at the endstops (first pass)
      G1 X-5 Y-5 Z-5 F1800 S2 ; go down a few mm
      G1 S1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
      G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; move X+Y to the centre
      config.gcode
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M665 R274 L494 B150 H250 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M550 PAB-Delta3 ; Set machine name
      M551 Pxx ; Set password
      M552 S1 ; Enable network
      M587 S"xx" P"xx" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S1 ; Drive 0 for x
      M569 P1 S1 ; Drive 1 for y
      M569 P2 S1 ; Drive 2 for z
      M569 P3 S1 ; Drive 3 for E1
      M569 P4 S1 ; Drive 4 for E2
      M569 P5 S1 ; Drive 5 for Toolchange rotate
      M569 P6 S1 ; Drive 6 for Toolchange lift
      ; Motor remapping for toolchanger
      ;M584 X0 Y1 Z2 U5 V6 E3:4 P6 ; Driver X=0, Y=1, Z=2, U=5, v= 6, Extruder 3 and 4, remapping the drives
      ; Configure Drives
      M350 E1:1 I0 ; Configure microstepping without interpolation
      M350 X16 Y16 Z16 U16 V16 I1 ; Configure microstepping with interpolation
      M92 X160 Y160 Z160 U160 V160 ; Set steps per mm for axis
      M92 E663:663 ; Set steps per mm for extruders
      M566 X1200 Y1200 Z1200 U1200 V1200 ; Set maximum instantaneous speed changes (mm/min) for axis
      M566 E1200:1200 ; Set maximum instantaneous speed changes (mm/min) for extruders
      M203 X18000 Y18000 Z18000 U18000 V18000 ; Set maximum speeds (mm/min) for axis
      M203 E1200:1200 ; Set maximum speeds (mm/min) for extruders
      M201 X1000 Y1000 Z1000 U1000 V1000 ; Set accelerations (mm/s^2) for axis
      M201 E1000:1000 ; Set accelerations (mm/s^2) for extruders
      M906 X1000 Y1000 Z1000 U1000 V1000 I30 ; Set motor currents (mA) and motor idle factor in per cent for axis
      M906 E2000:2000 I30 ; Set motor currents (mA) and motor idle factor in per cent for extruders
      M84 S30 ; Set idle timeout
      ; Axis Limit for z for Deltas
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 U1 S0 ; X endstop at high end, Y endstop at high end, Z endstop at high end, U endstop at low endSet active high endstops
      M558 P5 I1 H5 F120 T6000 ; Enable Z probe, invert signal and set dive height, probe speed and travel speed
      M557 R150 S20 ; Define mesh grid
      M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2
      M143 H2 S280 ; Set temperature limit for heater 2 to 280C
      M106 P1 S1 I0 F500 H1:2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1:2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      M563 P1 D1 H2 ; Define tool 1
      G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      ; Automatic saving after power loss is enabled
      M911 S19.8 R22.0 P"G91 M83 G1 Z3 E-5 F1000"
      Custom ANET A8
      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
      All I do here is under this license: CC BY-NC-SA
        M564 H0 does not apply to delta printers because of the increased danger of attempting movement before homing. To test motors individually, see https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Testing_the_motors_individually.
