    Movement without Homing Not Working (M564 H0) - SOLVED
    • SnowCrash
      SnowCrash last edited by SnowCrash
      I was previously told on the forum that putting the following line in config.g would allow me to move the effector without homing:
      M564 H0
      However, this doesn't seem to work as I'm getting the following error message:
      I've tried putting the above line in config.g and re-starting the Duet, as well as running the command from the command line. No luck.
      I've also tried switching between relative and absolute position (G90/G91) prior to running the command, but no joy either.
      config.g & config-override.g files are attached below.
      Also, here's my system diagnostics if it helps:
      1:36:38 PMM122
      Used output buffers: 3 of 32 (12 max)
      RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-956GU-DJMSN-6J1DL-3S86P-T9RZG
      Static ram used: 16152
      Dynamic ram used: 100560
      Recycled dynamic ram: 2072
      Stack ram used: 1224 current, 4408 maximum
      Never used ram: 7880
      Last reset 00:07:26 ago, cause: software
      Last software reset at 2018-12-12 13:29, reason: User, spinning module GCodes, available RAM 7816 bytes (slot 2)
      Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 10
      SD card longest block write time: 80.6ms
      MCU temperature: min 22.9, current 27.0, max 27.5
      Supply voltage: min 1.5, current 24.1, max 24.3, under voltage events: 2, over voltage events: 0
      Date/time: 2018-12-12 13:36:37
      Slowest main loop (seconds): 0.091238; fastest: 0.000044
      MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.21RC4(08b3)
        WiFi MAC address 5c:cf:7f:76:71:d8
        WiFi Vcc 3.30, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 16856
        WiFi IP address 192.168.1.110
        WiFi signal strength -64dBm, reconnections 0, sleep mode modem
        Socket states: 2 0 0 0 0 0 0 0
        === Filament sensors ===
        Extruder 0 sensor: no filament
        === Expansion ===
      I really need to be able to move the effector without homing first - how do I get this done?
      Many thanks in advance,
      SnowCrash
      0_1544622106203_config.g
      0_1544622120876_config-override.g
      • aidar
        aidar last edited by
        From other post :
        M564 H0 does not apply to delta printers because of the increased danger of attempting movement before homing. To test motors individually, see https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Testing_the_motors_individually.
        SnowCrash 1 Reply Last reply Reply Quote 1
        • SnowCrash
          SnowCrash @aidar last edited by
          Thanks @aidar!
