    PanelDue SD Card Connector Type
    • yummyfish
      yummyfish last edited by
      I've given the forum a serious search but may not know how to ask the question. I want to wire the PanelDue SD Card Connector to my Duet Wifi but can't seem to figure out what the connector type is that I need to between the PanelDue SD card connector and the Duet Wifi SD Card Connector. It's a ten pin connector labeled "CONN_SD".
      • StephenRC
        StephenRC last edited by
        It's in the documentation: https://duet3d.com/wiki/Connecting_an_LCD_control_panel#Other_combinations
        • yummyfish
          Thanks for your answer. I've checked over the documentation you linked and I don't see anything about the type of connector needed in that case. The four pin Molex connectors, etc. are listed, but not the type that is needed for CONN_SD (unless I'm just not getting it - which might be the case).
            It's a standard 10 pin 2 row 2.54mm pitch box connector that accepts IDC connectors for 1.27mm ribbon cable. For example, the 10 way version here http://www.ebay.co.uk/itm/IDC-Ribbon-Cable-10-14-16-20-26-34-40way-10-15-20-25-30cm-Custom-/182307853969. Maximum recommended length 400mm.
            • yummyfish
              Thank you so much! And thanks for updating the documentation!
