    Displaying the IP address using the N520 command
    Example setups and prints
    1706
    • NOVAprint
      NOVAprint last edited by
      I am trying to get the board to display the IP address when it is connected to the network. The command lines are at the very top. I am wondering if the issue if the decimals, I have removed the D (decimal) variable and it yields the same. I have varied the width all the way out to 70 and nothing happened. Here is the code. I am using an LED screen and although it would be great to buy a screen that displays outomatically, I want to make this screen work it seems reasonable to me.
      My code: the IP part appears, and three asterix.
      text R3 C5 F0 T"IP:"
      value R3 C30 F0 W27 D0 N530
      text R15 C5 F0 T"Hotend:"
      value R15 C50 F0 D1 W27 N79
      text R15 C80 F0 T"/"
      value R15 C87 F0 D0 W27 N179
      text R27 C5 F0 T"Bed:"
      value R27 C50 F0 D1 W27 N80
      text R27 C80 F0 T"/"
      value R27 C87 F0 D0 W27 N180
      text R39 C5 F0 T"Fan:
      value R39 C50 F0 D0 W19 N399
      text R51 C5 F0 T"Feed Rate:"
      value R51 C50 F0 D0 W19 N500
      ; hold one selectable item, off-screen, so that a click brings you to e_main:
      button R51 C132 F0 T"Get Started »" A"menu" L"e_main"
      • 3dmntbighker
        3dmntbighker last edited by
        N530 = octet 1
        N531 = octet 2
        N532 = octet 3
        N533 = octet 4
        I suspect all you need is octet 4. You probably have to build out the whole IP address appending the octets and periods one at a time.
        Scratch built CoreXY with Maestro
        Heavily modified Ender 3 with Maestro
        MPCNC work in progress with Duet WiFi
        NOVAprint 1 Reply Last reply Reply Quote 0
        • NOVAprint
          OK,, should each set of octets be on a seperate line or on one single line witht eh spaces counted out. Also is it possible that anyone out there has the display file for the duet wifi hd display? Even though it is HD the basic planning should be the same.
          • patakopecek
            patakopecek last edited by
            What screen do you use and how did you configure it on the duet wifi?
            • NOVAprint
              NOVAprint @patakopecek last edited by
              @patakopecek LCD 12864 and right now I am using a modified factury configuration obviously I have to change it. The first three lines of code are modified here. There is a guide that outlines how to program the menu screen, it is hared to do so far. If I take a few days I could get it done, but how has a few days?
              • Dougal1957
                Dougal1957 last edited by
                I Would suggest that it is on a Meastro not a WiFi!
                • NOVAprint
                  Sorry I did not make that clear this is the Maestro, perhaps I mispoke. At any rate the formatting and the question still stands is there any examples perhapos the menu from the Wifi can be translated over, can anyone post the menu files form the Duet Wifi as it lists the IP address on the HD screen
                  aidar 1 Reply Last reply Reply Quote 0
                  • NOVAprint
                    @3dmntbighker Do you have any menu code or formatting that could help with this, perhaps something that could copy and paste?
                    3dmntbighker 1 Reply Last reply Reply Quote 0
                    • aidar
                      aidar @NOVAprint last edited by
                      @novaprint Wifi doesnt support LCD 12864 as far as i know. Only Maestro does. So there are no menu files for Wifi.
                      • NOVAprint
                        NOVAprint @aidar last edited by
                        @aidar There is code that lines up the commands for the wifi. The code the N commands in the wifi shoild be common between the two platforms. There is no alternaive st of copmmands for the siplay on the LCD screen versus the HD The commands are the same, I would like to see the commands, would someone please post them?
                        • NOVAprint
                          NOVAprint @3dmntbighker last edited by
                          @3dmntbighker Do you have an example of lining up the N commands for this one, I wonder how many different ways the width, the decimals etc would need to be manipulated before I get it correct.
                          • aidar
                            @novaprint Not sure what code and commands you are talking about. LCD 12864 and PanelDue are two completly different things. PanelDue has its own firmware and talks to board via serial connection. Btw PanelDue firmware is open source so if you want to look at it .. https://github.com/dc42/PanelDueFirmware/releases
                            • NOVAprint
                              @aidar I will take a look.
                                On a PanelDue, to find the IP address go to the Console page, press the keyboard icon and enter M552.
                                • 3dmntbighker
                                  3dmntbighker @NOVAprint last edited by
                                  @novaprint said in Displaying the IP address using the N520 command:
                                  No, I'm not displaying the IP on my display.
                                  • NOVAprint
                                    @3dmntbighker THis is the code that I have so far:
                                      At present you have to display the 4 octets separately, for example:
                                      value D0 N530
                                      text T"."
                                      value D0 N531
                                      text T"."
                                      value D0 N532
                                      text T"."
                                      value D0 N533
                                      • NOVAprint
                                        @dc42 said in Displaying the IP address using the N520 command:
                                        value D0 N530
                                        text T"."
                                        value D0 N531
                                        text T"."
                                        value D0 N532
                                        text T"."
                                        value D0 N533
                                        thank you for that line of code, but at present, the display shows a series of asterixs (little stars) after each period. As if it is trying to show the information, but is somehow unable. I Had this unit connected to the internet last night and when I woke up it would not react to the same ISP numbers that it previously was assigned. The display of the little stars is consistent with the behavior that I was able to get before. The operating system is the latest from M3D. Just got it in November.
                                        • NOVAprint
                                          NOVAprint @dc42 last edited by
                                          @dc42 Yes it is connected to the internet and I am getting yellow and green lights on the Connecting network wire.
                                            What firmware version are you using? I don't think M3D has updated to 2.02 yet.
                                            • NOVAprint
                                              2.01 beta is the firmware that it shipped with. Do I need to update? Is that a new feature in 2.02?
                                              • NOVAprint
                                                  dc42 administrators @NOVAprint last edited by
                                                  This is working for me using 2.02:
                                                  text R54 C0 T"IP "
                                                  value N530 W15
                                                  text T". "
                                                  value N531 W15
                                                  text T". "
                                                  value N532 W15
                                                  text T". "
                                                  value N533 W15
                                                  I guess 530-533 were not supported in 2.02.
                                                  • NOVAprint
                                                    text R54 C0 T"IP "
                                                    value N530 W15
                                                    text T". "
                                                    value N531 W15
                                                    text T". "
                                                    value N532 W15
                                                    text T". "
                                                    value N533 W15
                                                    David,
                                                    The information did not make itself visible, the screen is not the more expensive LCD screen, it is the smaller LED one and I am now running the firmware 2.02.
                                                      @novaprint, which LED screen are you using? Does it display anything at all?
