    Delta finally printing...
    My Duet controlled machine
    1485
    • vwegert
      vwegert last edited by
      This is kind of a continuation of my old thread that for some reason appears to be locked. The build project was hit by a severe case of mostly job-induced procrastinitis, and then I had to make some design changes to include the Smart Effector... Anyhow, today I was able to do the very first test print, and I'm more than happy with the results.
      Benchy
      It's a bit stringy, but I still need to fit the high-quality PTFE tube and dial in the retraction settings. I'm also still waiting for the magnetic build plate. I didn't record too much footage in the process, but I'll probably throw together a demo and tour video to conclude the series once it's dialed in.
      • Danal
        Danal last edited by
        Yay! How bout a pic of the printer?
        vwegert 1 Reply Last reply Reply Quote 0
        • Eddiie
          Eddiie last edited by
          Nice.
          My Delta / Kossel is working again after taking a break from it for almost 2 years.
          It has a mixing head, happy it is working now. Happy for you too!
          I have stringing too, more like webbing. Not sure why.
          It has a hard time printing a bowl.
          • vwegert
            vwegert @Danal last edited by
            @danal Certainly - I just need to tie together a few loose ends, then I'll get some high-quality pics. I probably won't be able to do that till after Christmas, I believe...
            • vwegert
              sigh and another issue... Seems after replacing the cheap-o PTFE tube that I used for testing purposes, my equally cheap-o Chinesium extruder can't provide enough traction to reliably push the filament through. (It does, however, provide enough power to reliably chew through the filament. Which does not help a single bit.)
              I was half expecting to replace the extruder with something a little better at some point, but not that early on. Well, at least quality hardware is not that hard to get by any more.
              • Danal
                Danal last edited by Danal
                Just my personal opinion... based on data set of about 6 printers and about 12 to 18 extruders:
                Titan is HIGHLY OVERRATED. For any filament. I've tossed all of mine. Yes, I had real ones. Ordered from E3D in England.
                Cheap extruders that come on cheap printers are OK for PLA; they don't do flex at all, and they probably don't do anything out of a "sweet spot" of how much they can push.
                Bondtech is the best. Handles anything, including flex, stiff, springy, high pressure, low pressure, whatever. Has a tension adjustment but I've never had to set/reset it.
                The Bondtech clone that is built into the Prusa i3 Mk3 is very good, but not quite as good as a real bondtech. I've had them spit flex out the side, just randomly in mid print.
                Danal
                • vwegert
                  @danal Interesting to read that. I've actually ordered a Bondtech BMG - both due to reports similar to yours and due to the fact that I wouldn't want to order Titan parts from anyone else but E3D at the moment (too many fakes contaminating the market), and they are apparently lagging behind somewhat. Anyhow, the BMG should arrive next week or early in January, we'll see how that goes.
                  • Dougal1957
                    Dougal1957 last edited by
                    My goto extruder on a delta is the Zesty Nimble light weight and direct drive when mounted to the Smart Effector now running less than 1mm retracts with zero stringing
                    Danal fcwilt 2 Replies Last reply Reply Quote 0
                    • Danal
                      Danal @Dougal1957 last edited by
                      @dougal1957 said in Delta finally printing...:
                      GOT to try one of those...!
                      • fcwilt
                        fcwilt @Dougal1957 last edited by
                        Highly recommended. No more issues related to bowden tubes.
                        And very easy to feed new filament as you have easy access to the top of the hotend where the filament enters.
                        • vwegert
                          Okay... One Bondtech BMG later and the printer mostly does what it is supposed to do - it prints.
                          We'll see how that Benchy will turn out, but it looks promising so far. I will have to find a solution to acoustically isolate the BMG from the printer wall though - I'm getting some very prominent resonances at the moment...
                          • Wyvern
                            Wyvern last edited by
                            Cool, I have a delta (a non-duet) and although I love to see it go, it can be frustrating getting everything just right, probably going to sell it.
                            On mine I installed a flying extruder, never had an issue with retraction and I can print TPU no problemo, plus it looks cool.
                            Danal 1 Reply Last reply Reply Quote 0
                            • Danal
                              Danal @Wyvern last edited by
                              @wyvern said in Delta finally printing...:
                              The "smart effector" and a calibration before every print (slicer start g-code)... and... viola! Un-Frustrating delta!
                              My "BFD" (Big Fast Delta, a scratch-build 600x600mm printer) is now my "GoTo" printer for everything,
                              For example, it printed this. Flying Radio Controlled model, therefore all single layer prints, which are very touchy to get right. Canopy (windshield) was printed on a smaller delta with 1mm nozzle installed. BIG layers make transparent more transparent.
                              Anyway, deltas that self calibrate ROCK.
                              • Wyvern
                                Nice! how does it fly?
                                I've been toying around with the idea of a CF/PETG hybrid drone frame.
