    SOLVED Please Help.. Homing Z
    • TOFUATSU
      TOFUATSU last edited by
      I am almost don building my first printer. I have a CoreXY. I am using a Duet WiFi (original), DC42 ir sensor. I have the X and Y moving correctly and finding home.
      no matter if I use the home all or do one axis at a time. I always get the same G28 Error: G0/G1: insufficient axes homed.
      the Y endstop is located at the front left. the x endstop is on the left of the x carriage. the z probe is right by the hotend.
      here is my config file
      ; generated by RepRapFirmware Configuration Tool v2 on Sun Dec 16 2018 19:19:32 GMT-0500 (Eastern Standard Time)
      M667 S1 ; Select CoreXY mode
      M550 P"My Printer" ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M92 X80.00 Y80.00 Z1600.00 E418.60 ; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
      M906 X800.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X300 Y300 Z380 S0 ; Set axis maxima
      M574 X1 Y1 S0 ; Set active low and disabled endstops
      M574 Z1(I tried Z0 and Z2 here also
      ) S2 ; Set endstops controlled by probe
      M558 P1 H5 F120 T6000 ; Set Z probe type to modulated and the dive height + speeds
      G31 P500 X0 Y0 Z3 ; Set Z probe trigger value, offset and trigger height
      M557 X15:195 Y15:195 S20 ; Define mesh grid
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M563 P0 D0 H1 ; Define tool 0
      T0 ; Select first tool
      Stephen6309 1 Reply Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @TOFUATSU last edited by
        @tofuatsu You need to ads a S1 to all axis moves that are done before homing. For example: G1 Z5 S1 F3000
        TOFUATSU 1 Reply Last reply Reply Quote 0
        • TOFUATSU
          TOFUATSU @Stephen6309 last edited by
          @stephen6309
          Please forgive me.. I am really new. I looked into it.. are you talking about adding S1 command in the homeall.g file? I think they are present. This is my file
          ; homeall.g
          ; called to home all axes
          G91 ; relative positioning
          G1 S1 X-305 Y-305 F1800 ; move quickly to X or Y endstop and stop there (first pass)
          G1 S1 X-305 ; home X axis
          G1 S1 Y-305 ; home Y axis
          G1 X5 Y5 F6000 ; go back a few mm
          G1 S1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
          G1 S1 Y-305 ; then move slowly to Y axis endstop
          G90 ; absolute positioning
          G1 X15 Y15 F6000 ; go to first bed probe point and home Z
          ;G91 ; relative positioning
          ;G1 S2 Z5 F100 ; lift Z relative to current position
          ;G90 ; absolute positioning
          • Stephen6309
            @tofuatsu I finally got around to upgrading my corexy with the presale DuetWifi from 1.18 to 2.02RC6 and had to change my homing files.
            My homeall.g:
            ; generated by RepRapFirmware Configuration Tool on Thu Oct 06 2016 12:46:23 GMT-0400 (Eastern Daylight Time)
            ; Relative positioning
            G91
            ; Lift Z
            G1 Z5 S1 F9000
            ; Move towards X and Y axis endstops (first pass)
            G1 X-405 F3000 S1
            G1 Y-305 F3000 S1
            ; Go back a few mm
            G1 X5 Y5 F9000
            ; Move slowly to axis endstops once more (second pass)
            G1 X-405 F360 S1
            G1 Y-305 F360 S1
            ; Absolute positioning
            G90
            ; home the Z axis
            G1 X200 Y150 F9000
            G30
            • TOFUATSU
              @stephen6309 hummm I copy and pasted your homeall file... it still fails when it tries to home the bed. to does move differently.
                dc42 administrators @TOFUATSU last edited by
                @tofuatsu said in Please Help.. Homing Z:
                Check that there are no commands in your deployprobe.g and retractprobe.g files, unless you are using a BLTouch - in which case, check that they are the correct commands.
                • TOFUATSU
                  TOFUATSU @dc42 last edited by
                  @dc42 Thank you so much!!! That was it!!
