    CR10s Configuration
    My Duet controlled machine
    • gbiski
      gbiski last edited by
      I am trying to setup my CR10s with a Duet wifi. I have the stock heated bed and one Micro Swiss all metal hot end.
      Does any one knows what values shall i put on the configurator for the following:
      Heater Type Temp. Limit PWM Limit R25 β C Sensor Channel
      Bed
      E0
      Also what gcode shall i add to the config file for the run out filament sensor of the Cr10s?
      Is the M574 X1 Y1 Z1 S1 ; Define active high microswitches is enough ?
      thanks a lot
      George
        I can't help with the thermistor settings because I don't know the CR10S. You can normally leave the PWM limit and sensor channel at their default values. If you search this forum for CR10S then you will find other users with that printer - maybe one of them can help.
        Filament sensors are configured using M591, see https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M591_Configure_filament_sensing.
        • Hélder Rocha
          Hélder Rocha last edited by
          HI,
          i am trying to config a microsswiss hotend for my Duetwifi and i cant find the proper settings for it as there are for the E3D! My printer is the CR-10 but it have allmost nothing, exept for the frame as stock. I can find online help with the Bondtech, with the Bltouch settings but nothing for the microswisss. Any help?
            Phaedrux Moderator @Hélder Rocha last edited by
            @Hélder-Rocha Do a search for Ender 3 thermistor. Creality uses the same thermistor for all of them I believe and the values for the Ender were sussed out a while ago.
            • Hélder Rocha
              Phaedrux,
              tks a lot. I`ll check it out.
