    Failed to load height map
    • hyppo
      hyppo last edited by
      k what could b the reason for this error?
      Error: G29: Failed to load height map from file heightmap.csv: invalid grid
      i dont have probe yet on my delta so im using the manual leveling, and trying to save to height map so i dont have to constantly do it, but im getting error massage, what cud b the prob
        It doesn't seem to like what ever you have configured in your M557 grid layout command.
        If you send M557 in the console what does it return?
        • hyppo
          grid not defined
          • hyppo
            ok the how do i save grid in correctly
              https://duet3d.dozuki.com/Wiki/GCode#Section_M557_Set_Z_probe_point_or_define_probing_grid
              https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
                dc42 administrators @hyppo last edited by
                @hyppo said in Failed to load height map:
                grid not defined
                You must have defined a grid using M557 before you did the manual mesh probing. Put that same M557 command in config.g.
                • hyppo
                  here to i add the g29 s0 after probing or b4?
