Firmware 2.02 released!
@hornetrider Can you post your other homing files? Homex looks correct.
thanks for the quick reply.
The homeall.g looks similar to the homex.g as it was generated with the RepRapFirmware Config Tool.
It uses the same controls just for all axes and including the G30 for the Z Probing.The strange thing is, before the FW update (done 02.01.19) the homing worked fine...
Also
G1 S1 X-215 F1800
G1 X6 F6000 ; go back a few mm
work fine as the X-Axe goes back the distance after hitting the first time the switch....But at the end of the script the error message appears.
pls see bellow
G91 ; relative positioning
G1 S1 X-215 Y-302 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 X5 Y5 F6000 ; go back a few mm
G1 S1 X-215 Y-302 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X15 Y15 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 S2 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning
Tried also to replace the Sx by Hx and it didn't help other than generating an error message less precise then the G0/G1
This is kind of anyoing.
BTW
in the SYS Folder, what files should be there.
After Update I have far more there...
@hornetrider Your
homeall.g
looks OK to me. Though I don't useG30
in my setup so not sure if there is anything needed to adjust.Regarding the amount of files in
/sys
: the new simplified update with just on ZIP file contains all the various update files for Duet Wifi, Ethernet and Maestro. This will add some files to your/sys
folder that you don't need but they don't do any harm either. -
thx.
Did you have a Cartesian Style Printer?
Have you had to change any commands after update?I am going crazy...and most likely it is something tiny...like allways...arghhh
@hornetrider Yes, I do have a Cartesian printer and since I follow along all Beta/RC versions and usually immediately adapt to all introduced changes I did not have to adjust anything special here.
Here's my
homeall.g
for comparison:; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool on Sat Apr 28 2018 20:07:26 GMT+0200 (CEST) G91 ; relative positioning G1 H2 Z2 F3000 ; lift Z relative to current position ; X and Y G1 H1 X-300 Y-300 F3600 ; move quickly to X and Y axis endstops and stop there (first pass) G1 X5 Y5 F3000 ; go back a few mm G1 H1 X-300 Y-300 F360 ; move slowly to X and Y axis endstops once more (second pass) ; Z G1 H1 Z-300 F900 ; move quickly to Z axis endstop and stop there (first pass) G1 Z2 F3000 ; go back a few mm G1 H1 Z-300 F180 ; move slowly to Z axis endstop once more (second pass) G90 ; absolute positioning
@wilriker
HI Manuel
just used your setup and it didn't work....It seems to stop right after x/y hit the first time the limit switch...
Ric
I think the problem may be the I0 in M906 and the S0 in M84. My guess is that this sets the motor currents to zero immediately after the homing move stops, and that is flagging the axes as not homed again.
You are a genius!
After setting I0 in M906 to I0.1 it works fine again!Thank you very much!
@dc42 thanks for incorporating my feedback on the latest PanelDue firmware with both the Stop button taking priority and actually stopping the printer immediately as well as the 2mm/s federate on the extruder.
Really liking the notification system on the latest firmware! Nice work to everyone involved.
David, I am having trouble with Z height reliability. I am using your Z IR probe, I have a slightly tinted glass heat bed approx. 6mm thick. I have placed a piece of black paper under the glass at my home location. I test it by homing the printer then entering G1 Z0 and most of the time the Z gap is tight against the glass (to tight to print first layer). I repeat the procedure with G92 Z0 after adjusting the Z gap then runG30 S-1 and enter value in M558. Is there anything I can do to improve this.
I am running 2.02
M574 X1 S0 ; Define active low and unused microswitches
M574 Y2 S0
;M574 Z1 S1
M564 H0
M558 P1 X0 Y0 Z1.297 H0 F500 T3000 ; Set Z probe type to modulated, the axes for which it is used and the probe + travel speeds
G31 P500 X0 Y0 Z 1.1 ; Set Z probe trigger value, offset and trigger height -
G1 Z0 should place the nozzle just touching the glass if you have set the trigger height correctly in the G31 command. The printer will command the nozzle to the first layer height before it prints the first layer, for example it will send G1 Z0.2 if your first layer height is 0.2mm.
If you are using a config-override.g file, check that the trigger height isn't being overwritten by another G31 command in that file.
Just upgraded my WorkBee to firmware 2.02 as I have to do some parts. There was no change required in the configuration files.
But, as I had to machine a cylindrical shape, I can clearly see a possible problem with the G2/G3 segment length correlated to the arc radius. The piece was milled at very low speed, so the cutting tool could not make such regular marks.
The whole GCode is made up of G2/G3 for the cutting. The circle radius varies between 15mm and 18mm and the facets are perfectly aligned between the two diameters.Is there a way to control the relative segment length or chose between new and old behavior?
Perhaps I should change the firmware to reduce the segment length when the commanded speed is low. What would be a typical milling speed?
@dc42 It depends a lot on material and cutting tool. Standard WorkBee can't exceed 2500mm/min for screw driven, but it can be as fast as 10000mm/min for belt driven one. Also, CNC machining can have two passes (and most of the time it does so!) - roughing, when the bulk of the material is removed and quality is not important as there is some left over material for the second pass, and finishing, when just a fine layer of material is removed and the machining parameters are focused toward surface quality. The picture shows a piece half finished, with the remaining finishing to be done with a different setup.
P.S. Maybe adding some parameter to upper limit the segments length?
What would you consider a reasonable upper limit on segment length? 1mm?
@dc42 It depends on what needs to be machined. In the photo the facets are about 1.2mm wide. So 1mm would not be significantly different. Honestly I would consider something like 0.1mm a lot more suitable, but that is because the WorkBee accuracy is around that. If a CNC has much better mechanics, even 0.1mm might be too much. That is why the segment length upper limit should be configurable!
Right now I have an Al piece with corners machined with 3mm radius. I can clearly see the facets. A picture will come soon... once the machining ends and I can clean the Al part for a photo!
Rather than making the upper limit configurable, I think it better to make it speed-dependent. The reason I made it radius-dependent in the first place is that users complained that in 3D printer mode, the maximum speed achievable for G2/G3 commands was too low. But speeds are much lower in CNC machines anyway, so I could leave the segment length at 0.1mm unless the requested speed requires a longer segment and the radius allows that without losing much accuracy.
