    Layer shifting
    577
    • peirof
      peirof last edited by
      I put this question here because I have no idea what is due, I explain the problem:
      • Delta printer
      • PETG
      • Printing speed 45 mm / s
      • Temperatures: 240/75
      • Layer height: 0.15 mm
      The problem occurs after the first layers, never at the same height, many times, only occurs once in the entire model, sometimes occurs, 2 or 3 times.
      What happens is that the layers move, maybe 1 mm, at most 2, the first few times I pass, I thought it was because the straps of the towers were not tense, and I tensed, the same thing happened to me again . Then I thought they were very tense ... and loosen them, but nothing. The same.
      The only thing that occurs to me at some point, the engine of a tower loses steps ... but is there any way to check this?
      I am using thiese currents in config.g:
      M906 X1200 Y1200 Z1200 E800 I40
      How do you see them?
      Two main doubts:
      How can I check if some engine is losing steps?
      What are the recommended currents for Nema 17 motors?
      P.D .: I take this post to congratulate Christmas to all .... Even David. XD.
      MERRY CHRISTMAS!!!!!!!!!!!!.
      Let's see if Santa Klaus brings you an OLSSON RUBY
      Stephen6309 1 Reply Last reply Reply Quote 0
        You could configure stall detection to report any stalls.
        Current should be set around 85% of the motors rated max current.
        Is the plastic curling and getting caught on the nozzle? Maybe you need to add some Z hop.
          Which Duet are you using, and what is the specification of the motors?
          • peirof
            Its a Duet 2 board with 2.02RC7(RTOS) (2018-12-22b2) firmware... And until tomorrow i hace no acces ti motors, are stocks motors, Nena 17 of 1.8 degrees
            • Veti
              Veti last edited by
              there are many different nema 17 motors. each with their own current rating.
              also is it a duet wifi/ethernet/maestro.
              are you using 12v or 24v?
              • peirof
                Duet 2 wifi and 24v
                • Stephen6309
                  Stephen6309 @peirof last edited by
                  @peirof Since you're using PETG, is the nozzle leaving blobs behind? The blobs left behind would cause skips when they got left behind and when I upgraded to the silicon socks on my e3dv6, the blobs disappeared.
                  • peirof
                    Maybe.... i have blobs with PETG....
                    I will try
