    X, Y and Z stop connections with Reed sensor
    • Army61
      Army61 last edited by
      Hello! I've reached to X, Y, and Z Stop connections for Duet Fifi controller. Each connection has 3 contacts (pins), but for my BFB 3D Touch printer are Reed (magnetic) sensors with two wires.
      Do I think right if I want to connect one wire to a Stop pin and the other to a +3.3 V pin? Then the ground pin will be free. Is will be correct?
      Army61 1 Reply Last reply Reply Quote 0
      • Army61
        Army61 @Army61 last edited by
        Stephen6309 1 Reply Last reply Reply Quote 0
        • Stephen6309
          Stephen6309 @Army61 last edited by
          @army61 One wire to the ground pin and the other to the signal pin. The 3.3v pin is not used.
          dc42 Army61 2 Replies Last reply Reply Quote 2
            dc42 administrators @Stephen6309 last edited by
            @stephen6309 said in X, Y and Z stop connections with Reed sensor:
            That's correct. Use the two outer pins of each endstop connector.
            • Army61
              Army61 @Stephen6309 last edited by
              @stephen6309 Thank You so much!
